Dynamic Mode
Aplogies, thanks for the info. I’m looking at a 2016 340hp. I’ll inquire with the dealer if it has Active Exhaust.
Do you have a URL? The site Google is showing appears to be dealer facing and requires dealer related credentials to register.
Thanks. I used this site’s VIN decider tool for the car in question and one that I know has Switchable Actuve Exhaust. Both searches showed no active exhaust listing, Switchable or otherwise. Curious if this tool pulls from Topix.
Depends on what you mean by exhaust note. It makes a huge change on my car - in dynamic, you can hear the valves open in dynamic under load, and it gets loud. Doesn't do that with dynamic off.
Of course, since I pulled the fuse, it's always loud.
Putting in dynamic does not alter this behavior - for cars without the switch. For cars with the switch, putting in dynamic automatically switches the exhaust to noisy mode.
On the older models used to be F43. Not sure if that still works on the newer models, seem to remember reading a thread that indicated this is no longer possible.
Have to disagree - being in dynamic definitely makes a difference in exhaust sound. I have active exhaust, but not switchable active exhaust.
This applies to earlier cars; they got rid of the electric vacuum pump around MY16-17, and use engine vacuum instead. My pump and valves are noisy, which is why I pulled my fuse.
https://www.dropbox.com/s/szc3vze5ol...haust.pdf?dl=0
If you put it into dynamic, the exhaust goes into noisy mode 100% of the time from idle all the way through the rev range as I think that is what the OP is looking for - or only under load?
