Dynamic Mode
Dynamic Mode
So my 2014 V8S feels quicker in regular mode, and the exhaust pops much more. Seems to slow a bit in dynamic, and the exhaust doesn’t pop and crackle nearly as much. I drive in regular mode much more often, wasn’t sure if this was normal as I expected more pops and crackles and a little better response in dynamic.
Dynamic in the ‘14 V8S should...
Tighten up steering (feels a bit heavier)
Suspensions gets a bit tighter (active dampers)
Transmission wants to shift more readily (takes less right foot to cause a downshift)
Activates active exhaust (which might already be on if you pushed the button)
Turns some interior lights red
Some of this stuff uses learning, so if you drive it sedately in Dynamic, it might learn to be a bit less peppy. I’ve experienced something like that before.
If the settings for Dynamic have been “adjusted “ to negate the stiffer suspension, steering, engine and shifting settings, Dynamic won’t be changed from “normal”.....but shouldn’t be slower.
Take a look at how your Dynamic is configured.
mine is a ‘16 so may differ from yours...but I doubt it.
Received 3,226 Likes
If you can find someone in your neck of the woods with the right equipment and knowledge/experience then get it done, you won't regret it.
A dealership could do it but none will unless you are on extremely friendly terms with them.
ahost
XE ( X760 )
21
01-15-2020 04:21 PM
