Dynamic vs. Sport Mode
No it does not go on or off with sport mode. You can either turn it on manually by pressing the button below the gear shifter, or it goes on in Dynamic mode when selected automatically. You asked why it gets LOUDER when in Sport mode, and I was just saying that by going to Sport Mode instead of just "D", it dumps more gas to give better response, and livens up the fun noises coming out the back
You can have active exhaust without the button, in which case the exhaust is computer controlled. If you have the switch, you can control the exhaust manually as well. In the US at least, all current f-types come with active exhaust, but the button is an option, which should be standard in my opinion.
In previous years it was possible to get the car without active exhaust - a whole different exhaust was fitted without the valves.
Ok so Dynamic Mode makes it slightly louder and Sport Mode makes it even louder? I haven't noticed a sound different in Dynamic Mode, only Sports Mode for some reason.
Key difference in my mind:
- Sport mode alters the shift points, so that switching to Sport mode will instantly put you in higher rev and (in most cases) give you more torque.
- Dynamic mode alters the throttle response, and will give you more acceleration for your push on the accelerator pedal.
For the most fun, use both at the same time!
Pcar2Jag (09-18-2020)
Vinnie77
02-08-2018 03:51 PM
