E85?
Good afternoon gents. I'm looking if anyone has either run full e85 in their v8 f type? If so what upgrades did you have to make to allow for it?
Or if anyone has the information to how the range rover flex fuel cars are determine ethanol content and adjusting fueling for it I could maybe apply that to our cars.
It's locally available to me, much cheaper than racegas and provides both cylinder cooling benefits and higher "octane", proven power gains across every platform its tuned on. I understand it requires higher quantity for the same energy when compared with gasoline but I've run it on different platforms with great results. Also theres the benefit of allowing a leaner mixture while maintaining safe fuel targets. All this to say, it's like racegas that's available nationwide at this point.
I would be tuning for the e85, I'm not implying any Joe schmo should go fill up and instantly be making more power. On some basic questioning it appears to me the RR flex fuel cars essentially are "guessing" ethanol content based off short term fuel trims and adjusting according but I'm not sure what the f type lpfp and hpfp will max out at, e content wise. My wife's q60 can only take e30 mixture. Anything greater would require fueling upgrades.
It's locally available to me, much cheaper than racegas and provides both cylinder cooling benefits and higher "octane", proven power gains across every platform its tuned on. I understand it requires higher quantity for the same energy when compared with gasoline but I've run it on different platforms with great results. Also theres the benefit of allowing a leaner mixture while maintaining safe fuel targets. All this to say, it's like racegas that's available nationwide at this point. The car performs fantastically well.
Currently I have no worries about octane as I'm running a 50/50 water meth injection kit that the engine is not reliant on, it's simply auxiliary cooling with the added benefit of raising octane. It's great, changing fuel to e85 I would retune for it. It's interesting to note your check engine light came on at such a small mixture. Do you recall the codes? Perhaps short term fuel trims were being maxed out?
High EtOH blends do indeed raise the research octane, allowing you to advance the spark for a bit of additional HP at high rpm, but the combustion energy content declines with the additional oxygenate content, reducing fuel economy, but also more importantly reducing torque. Motor Octane decreases as Research Octane increases as additional EtOH is added to the blend.
You can also safely run a slightly leaner fuel mixture than gasoline allowing for a more complete burn and less fuel to compensate that need for more e85. Of course you don't need to do this and it's better mpg will come with better power and more complete burn.
I plan on getting a custom e30 or e40 tune pretty soon. If you plan on running any mixture of e85 you should get tuned for it. Running e85 requires 30% more flow from the injectors. So if you are just throwing e85 at the car, it's not getting the right amount of fuel. You will run leaner and end up just messing things up. From a cel to engine damage. Get a tune, so you can take full advantage of the ethanol.
Terrance39 (10-30-2019)
Not to revive an old thread, but have been looking into this for the past year as I acquired a 2013 XF 5.0 Supercharged, and was frustrated when I got it and it did not have the flex fuel option. Some Jaguar XFs, V8 and V6, come standard with full flex fuel, same thing with the range rovers, so out of curiosity, I looked up a VIN that was flex fuel and another VIN of a car that was not flex fuel capable, turns out they have the same part number for the fuel pump, my curiosity is (since JLR does not really change much between Xf supercharged, XFR, and XFR-S, as well as the entire brand and just slapping the 5.0 in every larger vehicle without any major changes) is if they put the same injectors and even the flex fuel sensor in all their vehicles, and might just require a dealer remap in order to make our cars flex fuel capable. I know someone in California is a tuner with an XKR (old drivetrain with 6 speed auto, Jaguar didn't make that flex fuel capable) and I believe he is running e30 or so, not sure on the details for that XK as it was some other XF owner telling me this who was thinking about getting a tune himself. So bottom line, I do believe our cars are flex fuel capable bone stock, we just need to find the right tuner, I reached out to Velocity AP and they said they are playing with it. I really do wish I got a flex fuel car instead.
Reviving this again. I am tuned for flex fuel in my Camaro ZL1 and make about 100
hp on e70 blend (highest my injectors and fuel pump with booster will support). I’d love to flex tune the F-type also. I already have HP Tuner for the ZL1. Anyone know how much head room the F-type injectors and fuel pump have? I can’t believe no one else is trying this.
boostedxf (09-20-2022)
