Easiest injector removal method for LODGED injectors.
Here is how i did my injectors. i didn't like the video of the guy using the engine hoist because it pulled the injector straight up from an angular socket and almost broke an injector.
I decided to use a ratchet strap to give a large amount of pull assistance as i used my shoulder to control the exact angle of the strap and the slide hammer to lodge the injector loose.
hope this helps you guys.
zochmenos (01-13-2023)
Life And Projects By Austin YOUTUBE (01-11-2023)
it was straight forward. just use a skim layer of Vaseline on the Teflon and the o rings so they easily slip into place without being pulled off. dont use spray lube as they will break down seals over time..
Life And Projects By Austin YOUTUBE (01-12-2023)
The following 2 users liked this post by bfrank1972:
Life And Projects By Austin YOUTUBE (01-14-2023),
SouthSider (01-14-2023)
Because bending is the first sign of breaking them. And if they get broken in the head of the motor you will need to rebuild the top end of the motor because the heads have to come off. That’s why I was so happy in the beginning.
ALL THE PARTS WERE COURTESY OF THIS THREAD
PARTS TO ORDER:
INJECTORS $800
INJECTOR SEAL TOOL $70
INJECTOR SEAL/CLIP KIT $50
DOCS:
FUEL PRESSURE RELEASE
JLR MANUAL INJECTOR REMOVAL PROCEDURE
DJS (01-15-2023)
this entire process came from a fellow member this is his thread. u updated the parts links to the latest and cheapest!
PARTS TO ORDER:
INJECTORS $800
INJECTOR REMOVAL TOOL $32 INJECTOR REMOVAL TOOL $32
DOCS:
PARTS TO ORDER:
INJECTORS $800
DOCS:
BR
Andi
