Easy ECO Stop/Start disable - Applicable to cars without 2nd battery
Old 03-21-2017, 09:04 AM
DJS's Avatar
DJS
DJS is offline
Received 2,112 Likes on 1,410 Posts
Actually, all the switches feed into the JaguarDrive Switchpack control module, which transmits actuation info onto the CAN bus to the appropriate modules.
https://www.dropbox.com/s/wskjex70o2...ntrol.pdf?dl=0
  #42
Old 03-21-2017, 01:06 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
Modules = virtual relays. At least, that how my little pea brain comprehends it.
  #43
Old 09-04-2017, 01:21 PM
dantes's Avatar
Just did this - thank you! Will update if any issues.
  #44
Old 09-05-2017, 05:58 AM
Tel's Avatar
Tel
Tel is offline
Talking
Well, two years plus down the line, no issues. I even plugged it back in to check if it still worked...it did!
AaronLin (09-05-2017)
  #45
Old 05-12-2018, 10:38 AM
mleskovar's Avatar
Originally Posted by Buckingham
Now could someone figure out how to latch on the loud exhaust?
Are you referring to the in cabin noise? On the XF there's actually a mechanical noise enhancer (like a speaker) on the firewall connected by tubing to the engine that amplifies the noise and directs into the cabin behind the dash. I bet it's on the F type as well since the intent is to give the car a more "sporty" sound. Jaguar calls it a "symposer" I think. I blocked mine with a rubber stopper from the hardware store. No tools needed, just disconnect by hand and install plug. Doesn't totally eliminate but muffles it down to a much more discreet level that isn't so annoying.
  #46
Old 06-29-2018, 07:03 PM
eeeeek's Avatar
Thank you so much for this.
  #47
Old 07-03-2018, 02:01 AM
NavyBlue's Avatar
Thanks for the needed post.
Here's also a great Youtube video:
Michael211 (10-07-2021)
  #48
Old 07-03-2018, 02:11 AM
NavyBlue's Avatar
However, does anyone know the location of that module for a convertible? since that module is not in the same place...
Thanks,
  #49
Old 07-03-2018, 02:20 AM
Greggbhill's Avatar
2018 MY update:
i disconnected the “purple” bundle wire plug on my new 2018 R as I did in earlier parts of this thread for my 2016 V6S, and it works the same.
the battery and eco-start/stop thingy are in different locations, and it is a little tricky getting the plug undone due to it’s new tight location.
Battery now on right against rear edge, with eco-stop/start thing now on left (“purple” wire bundle clip)
With “purple” wire clip connected (enabled) - as from factory
With “purple” wire clip disconnected (disabled)
Cosshog (03-08-2021)
  #50
Old 07-03-2018, 02:23 AM
Greggbhill's Avatar
Thanks,
see my new post above... I have a 2018 convertible. My previous 2016 convertible had it on the opposite side of boot (passenger side)
  #51
Old 07-03-2018, 02:46 AM
NavyBlue's Avatar
Thank you very much, Gregg.
I found it, but the purple wire plug is on the left facing the left wall on my 17 vert. They really don't us to disconnect this.
I'm going to loosen the top nut to swivel that module out a little to have some working room to disconnect...
  #52
Old 07-04-2018, 11:24 PM
NavyBlue's Avatar
Got a long nose pliers to reach plug, easy disconnect.
Done.
Thanks,
  #53
Old 02-05-2019, 11:04 AM
KingFala's Avatar
Does anyone know if any of this applies to the MY19 F-PACE? Should be the same, but who knows.
  #54
Old 02-05-2019, 08:47 PM
AtTheJob's Avatar
Originally Posted by Greggbhill
2018 MY update:
Just wanted to share - I had disconnected this on my 2016 F-Type R for 3 years without any problems - This thread worked wonders for me back then! The dealer never made any note about it during any of the two annual services. The location of the 2019 F-Type R convertible is the same as this picture above. Just wanted to confirm this in case anyone was wondering.
  #55
Old 02-06-2019, 04:13 PM
FullChat's Avatar
Two years, two services - no problems. Thanks, Forum!!
  #56
Old 02-10-2020, 10:29 PM
uclabrruin1989's Avatar
Default me too
Originally Posted by Dougrobling
I did this 6 moths ago with no issues.
But I did notice that I can also no longer manually raise and lower the spoiler...
It still comes up and goes down at speed, but the console switch does nothing.
This is not a big deal to me, but I was wondering if others had seen the same...?
i've had the exact same experience. i bought my 2018 R coupe a few months ago and i immediately disconnected the plug, per this thread, and it has worked perfectly, no more annoying start/stop. today i tried manually changing the spoiler with the button (for the first time) and it didn''t work. i don't care about it either, i was just playing around.
  #57
Old 02-10-2020, 10:34 PM
eeeeek's Avatar
The spoiler doesn't manually deploy on the coupe like the convertible. The only way you can deploy it on the coupe is to turn the ignition on without starting the car and then you can raise it for cleaning mode. As soon as you start to drive, the spoiler will lower and go back to automatic.
  #58
Old 02-11-2020, 12:13 AM
Thumbs up i'll try again tomorrow
but that's not what the manual says.
https://www.ownerinfo.jaguar.com/doc.../proc/G1885762
but i'll try it and see what happens.
  #59
Old 02-11-2020, 12:27 AM
eeeeek's Avatar
There is more than one inaccuracy in the manual. The coupe, in the US, works as I described.
  #60
Old 02-11-2020, 03:21 AM
Cleantex's Avatar
What could be interesting, to have the exact description of the wires on the plug to see where they go. After, to cut the start/stop wire at a certain point and integrate a remote control receiver into the line, to be able to toggle the connection as desired and that keeps the last state. Is there some circuit description existing with the right wire colours outside Jag plant ? I think that this is not part of the Can-bus ?
Quick Reply: Easy ECO Stop/Start disable - Applicable to cars without 2nd battery
