eco mode - default to off?
#61
#62
Yes, but with later cars with no second battery the way to go should be to disconnect the small plug on the battery management box in the trunk. There are some descriptions in the forum and it is not only for F-Type. I didn't pull it yet because I want to take the time to be sure that no errors are created. I would really prefer a simpler way. I was beginning not to like this already on my Touran, shutting down the motor every time before my garage door during opening. Just silly. For VW cars you find modules on the market and such module I build inside, it remebers just the last choice and bring it back after every restar, perfect. But for Jaguar and specially F-Type you dont find. So pulling the plug should be an option.
Having had it unplugged for two years now, I have personally found no issues and I have been in for annual service twice. The only error you can cause is if you hit the button to turn on the stop/start, you get a message that says something to the effect that it is unavailable.
#63
The easiest way to disable the eco start/stop is to push the button after you start the car. It takes less time than fastening the seat belt. Start/dynamic/eco off/seat belt. It's all done before the engine comes off fast idle.
This is offered without proof and smells of conspiracy theory BS. Engine wear? Debatable. Engine wear occurs when running, and also when starting. Fuel pump is running less, and injectors are being used less. The only data I've seen is decades old, but I have changed more fuel pumps and injectors than engines. Starter wear? Yes, but noticeable in the average time of ownership? Systems were redesigned around this feature. I dunno. If you do, prove it.
Is it fishy that I have to help the environment by having my trash hauled rather than being allowed to burn it in my front yard? No. It makes sense.
#64
This is offered without proof and smells of conspiracy BS. Engine wear? Debatable. Engine wear occurs when running, and also when starting. Fuel pump is running less, and injectors are being used less. The only data I've seen is decades old, but I have changed more fuel pumps and injectors than engines. Starter wear? Yes, but noticeable in the average time of ownership? Systems were redesigned around this feature. I dunno. If you do, prove it.
#65
Even allowing for the hyperbole with "draining," yes, it does.
Stop the engine for 0.1 sec and the oil will still be there. Stop it for 10,000 seconds and it will have drained. How about 0.2 sec? Viscosity is such that it won't have drained. If it were enough time, then oil changes would be pretty quick. How about once the fluid has effectively drained, but film strength still has it clinging to the moving parts? Five seconds? 30? 120?
I'd like to see data on that more than a "the sky is falling" freakout that reduced emissions are a plot to make us buy more engines.
#66
#67
Doesn't address my questions though, so I'll be more clear. How much idling time wear offsets startup wear when the engine is hot? How much stopped time does it take before the startup cost (in wear) starts to increase?
#68
Shot in the dark, and wide of the mark. Also, not at all relevant to the discussion.
#69
Dont forget that the juice from the battery is not gratis. It must be reloaded from fuel consumption. And there is something else. The automatic clutch in our gearbox make the car advancing at slow speed, when you release the brake pedal. Not the case with double clutch and can be surprising when you stand behind a car in front. So you must brake again. What could result in another showdown.
#70
I just accidentally figured out why our car slams itself into Park, stopping on the transmission gears, whenever you crack the door open while rolling to better see a parking spot line, or a curb while backing up. Some cars don't do that, so the transmission survives but you don't.
One bad nanny idea leads to another bad nanny idea. This is what happens when engineers and activists with very little driving experience try to tell people how to drive with an agenda.
#71
a turbocharged car that requires a 30 sec idle before each shutoff to avoid oil starvation to prevent turbo failure?
Old fashioned mineral oils would 'coke up' in the heat of a non-spinning turbo unless you gave it time to idle before shutdown. Today's oil base stocks are not as sensitive to the heat (and many of today's turbos have water-cooled bearings, with electric circulating pumps for good measure, if the sensors see heat from spirited driving).
Our other exotic, a turbocharged car from the 1980s (97K miles), has the original turbocharger. Mobil 1 used since purchase in 1993.
#72
^^^ That hasn't been true since synthetic oil became available 3 decades ago.
#73
The reason is to give the turbo time to wind down before removing oil pressure. It applies to modern turbos especially, but is common sense to let any hot engine cool down before removing cooling altogether. It's in modern owners manuals, too, even cars with auto stop start, stupidly.
Carbuff2 (02-09-2020)
guestlinger
08-14-2012 09:06 AM
