ECU Tuning / F-Type Base - Have you done it? Opinions?
Rica Engineering is claiming a 60 HP boost with their remap, to just under 400HP. Anyone out there remapped with either Rica or another tuner?
Rica makes this claim, which I'm not sure how to interrupt: "100% dealership service compliant". My experience is that any remap automatically voids warranty, so I think they might be attempting to be tricky in their language. That said, every car I've done this with in the past had a mode to switch back to factory settings for services, so not sure it's a big issue either way. 60HP and their claimed curves are pretty damn enticing .
Rica Engineering Chiptuning
I don't know how they feel they can make that claim, and it seems ridiculous to me, but I do know that there is no way to hide a tune by flashing it back to OEM. This is true for at least two reasons:
1) Hidden fingerprints--there is a record of ECU reflashes, and
2) If your engine grenades and you flash the ECU back to OEM there will be no record of the events leading up to the engine malfunction--a dead giveaway.
Either or those two are enough grounds for a warranty denial on an engine repair/replacement.
You might want to check out the Eurocharged claims as well. The Rica tune is believable since Jag does nothing more than a tune to get the extra 40 horses from the S model. When my F-Type comes in, I'll do both a pulley and a tune to get more torque (that's where the fun factor really is).
Unfortunately I was told by Eurocharged that the ECU tune doesn't change the shifting program, it just adjusts the fuel-air mix and does some other stuff.
Can anyone confirm that the gear shifting remains unchanged with ECU tune?
Cambo (01-14-2015)
When I talked to Eurocharged, they told me on the V8S they needed to flash the OEM software for the R before they could get it to the gains they publish for the R. Likewise, they said they thought they would need to do the same to the base V6 to get it to the gains they claim for the V6S. However, at the time I'd talked to them, they'd never done it, so wouldn't guarantee it would work
I can get my head around why someone might think the pulley change is a little too aggressive.
BTW, could somebody measure the diameter of the SC pulley at the top of one of the ridges (in the middle, not at the edge)? That dimension should be close to being the effective diameter of the pulley.(Any V6 model please).
Yep, with all the uncertainty and general lack of information on tuning these engines, I'm most definitely staying stock until the end of warranty, if I keep it that long. Unlike you, I don't tend to keep cars more than 3 years because something new and improved always seduces me.
Honestly, even the base car is so tail-happy, I'm not feeling underpowered.
According to the specs, your base model is quicker than the S manual, and my tuned/pullied MINI is just as quick. I just wanted to get the torque up a bit from the based model (the torque is virtually the same on the base and S models)
As I suspected, Rica posts on their site the same results for the base as it does for the S. 940 Euro for 18 horses (4.7%) and 25 lb-ft isn't very cost effective. Eurocharged doesn't have a problem with putting a pulley on the 3.0L, but I'd like to hear from folks who have done it.
scooternva
20
09-27-2023 11:25 AM
