Electrical Issues
Hello Fellow X Type owners
I have some weird problems appear recently and wonder if anyone knows what the issue might be
firstly my washed fluid battle appeared to leak and the sensor said it was empty.
it was serviced and I need to change the sensor perhaps
then a few weeks later the AC starting acting strange, if its set to a temperate its either blasting hot air or freezing air which is not fun on a long trip.
the other day one of my headlights went out, pressing the button on the key fob the lamp flickers a little then some on and off again.
then the other bulb went out and the first one starts working again after a flicker but they are not bright.
Full beam has stopped working and then the lights completely stopped working at the front only.
if i turn them off via the stick I get the parking light.
nothing is reported on the dash display as far as the car looks to be concerned the lights are working normally
then The screen on the infotainment went pink for an hour and then started working again.
Any idea’s.
I have read battery might be an issue but its not reporting any issues, I also read about the connection area behind the front right wheel where the washer bottle is located.
Sounds like some electrical gremlins but concerned that there is not allot to go on.
Any idea’s.
Not sure what you mean by the battery “not reporting any drain”. But your symptoms definitely suggest that your battery is not fully charged. A new battery may well be the cure BUT (and please note this) a new battery will NOT be fully charged when purchased. If you install a partially charged new battery and use the car for short runs, or especially, short runs infrequently, then the battery will not ever reach full charge and the result will be persistent electrical issues.
As a first step you should *fully* charge the existing battery and verify the soundness of the battery and ground (earth) connections. Investment in a good battery maintainer (such as the CTEK) virtually guarantees no further issues.
Hello there
Just to follow up on this for other people.
My battery was tested and reported at being 100% holding its charge but the rating should be 850EN and it was 641EN
State of health was 75% and the F Type does not like this even if state of charge is 100%
Things that randomly fixed themselves when the battery was replaced.
1) AC not detecting the temperature properly
2) The windscreen washers thinking they were empty
3) Infotainment screen randomly going pink
4) Engine speed dropping when stearing
5) Start Stop started working again
Amazing and all good now.
As previous people said check that battery just because it starts doesn't mean its good.
Thanks for this follow-up report, Sean. The following comments are not related directly to your case.
When the car owner is faced with multiple problems arising at the same time, the initial reaction is to blame the manufacturer for producing yet another “lemon”. And we all know how nicely that plays into the myth of a lack of reliability.
A very experienced Jaguar mechanic once told me that “there are no lemons. There are only owners who do not understand their cars”. This is more true than ever.
On these forum lists we have dealt with owners unable or unwilling to even read the owner’s manual that came with the car, owners who do not understand the enormous electronic complexity of modern luxury vehicles (and the electrical power needed to feed them), well-meaning friends who cannot understand that a warning light regarding the ABS - coupled with a failure of the touch screen - can be traced to the fact that the F-Type is driven only twice a month and then only for 20 minutes or so….
The mantra: “battery, battery, battery” (meaning the battery itself and its connections) should be practiced daily.
This is not to deny that there can indeed be other causes for certain problems, and more involved solutions, but Occam was right. Most often, the simplest solution is the right one.
scm (11-03-2022)
Philip S-Type
09-04-2022 07:56 PM
Bluecortina76
09-15-2017 01:52 PM
