Electrical module fried?
Any ideas before I sell/burn to the ground? Dealer says they can't properly diagnose without the car, well I can't tow if it won't come on. Key fob battery and car battery all brand new. Events leading up to, Came home from deployment to bad battery, replaced (all 3) and added trickle charge quick connect to underhood access port. Car drove fine for 1.5 weeks. Yesterday I did a battery disconnect (used obd scanner) after that car decides to act this way. I've done multiple disconnect/reconnects before with no issues, but this time I'm assuming I fried a module somewhere.
Received 2,632 Likes
Apparently there are some reports that cheap Bluetooth OBD-II adapters can "immobilize" the car (different issue from the "car won't go to sleep after plugging something into the OBD-II port" problem). There's a few posts that mention the issue in the following thread: https://www.jaguarforums.com/forum/f...r-cars-213150/
Also, why can't you have the car towed? If it's because you can't shift the transmission into neutral, there's a manual override under the armrest on the side of the storage area. You need to pop off a cover, turn a locking tab counter-clockwise with a coin or screwdriver, and then pull up on the orange strap. That will place the transmission into neutral. The directions should be in your owner's manual or you can google it.
Carbuff2 (10-18-2022)
𝗨𝗽𝗱𝗮𝘁𝗲,
𝗜 𝗱𝗿𝗼𝘃𝗲 𝘁𝗵𝗲 𝗰𝗮𝗿 𝗮𝗯𝗼𝘂𝘁 30 𝗺𝗶𝗹𝗲𝘀 𝘁𝗼 𝗷𝗮𝗴𝘂𝗮𝗿 𝘀𝗮𝗻 𝗗𝗶𝗲𝗴𝗼 𝗳𝗼𝗿 𝘁𝗵𝗲𝗺 𝘁𝗼 𝗱𝗶𝗮𝗴𝗻𝗼𝘀𝗲. 𝗔 𝗳𝗲𝘄 𝗶𝘀𝘀𝘂𝗲𝘀 𝗜 𝘄𝗮𝘀 𝗵𝗮𝘃𝗶𝗻𝗴 𝗶𝗻 𝗿𝗼𝘂𝘁𝗲 - 𝗻𝗼 𝗱𝘆𝗻𝗮𝗺𝗶𝗰 𝗺𝗼𝗱𝗲, 𝗰𝗲𝗻𝘁𝗲𝗿 𝘃𝗲𝗻𝘁 𝘀𝘁𝘂𝗰𝗸 𝗶𝗻 𝘂𝗽 𝗽𝗼𝘀𝗶𝘁𝗶𝗼𝗻, 𝗽𝗮𝘀𝘀𝗲𝗻𝗴𝗲𝗿 𝘀𝗶𝗱𝗲 𝗱𝗼𝗼𝗿 𝗵𝗮𝗻𝗱𝗹𝗲 𝘄𝗼𝘂𝗹 𝗼𝗽𝗲𝗻 𝘄𝗵𝗲𝗻 𝘀𝘁𝗼𝗽𝗽𝗲𝗱, 𝗮𝗻𝗱 𝗰𝗹𝗼𝘀𝗲𝗱 𝗱𝘂𝗿𝗶𝗻𝗴 𝗱𝗿𝗶𝘃𝗶𝗻𝗴 (𝗿𝗲𝗴𝗮𝗿𝗱𝗹𝗲𝘀𝘀 𝗼𝗳 𝗹𝗼𝗰𝗸/𝗴𝗲𝗮𝗿 𝗽𝗼𝘀𝗶𝘁𝗶𝗼𝗻
𝗮𝗻𝗱 𝘁𝗵𝗲 𝗽𝗮𝘀𝘀𝗲𝗻𝗴𝗲𝗿 𝘀𝗶𝗱𝗲 𝘄𝗶𝗻𝗱𝗼𝘄 𝘄𝗮𝘀 𝘂𝗻𝗿𝗲𝘀𝗽𝗼𝗻𝘀𝗶𝘃𝗲.
𝗨𝗽𝗼𝗻 𝗲𝘅𝗶𝘁𝗶𝗻𝗴 𝘁𝗵𝗲 𝗱𝗲𝗮𝗹𝗲𝗿𝘀𝗵𝗶𝗽, 𝗜 𝗰𝗼𝘂𝗹𝗱 𝗵𝗲𝗮𝗿 𝘁𝗵𝗲 𝗰𝗮𝗿 𝗿𝘂𝗻𝗻𝗶𝗻𝗴 **𝗵𝗼𝗿𝗿𝗶𝗯𝗹𝘆** 𝘄𝗶𝘁𝗵 𝘁𝗵𝗲 𝗱𝗮𝘀𝗵 𝗳𝗹𝗮𝘀𝗵𝗶𝗻𝗴 𝗮𝗹𝗹 𝘀𝗼𝗿𝘁𝘀 𝗼𝗳 𝗹𝗶𝗴𝗵𝘁𝘀.
𝗦𝘁𝗮𝘆 𝘁𝘂𝗻𝗲𝗱 𝗳𝗼𝗿 𝘁𝗵𝗲 𝗰𝘂𝗹𝗽𝗿𝗶𝘁. 𝗜'𝗹𝗹 𝘂𝗽𝗱𝗮𝘁𝗲 𝗮𝘀 𝗻𝗲𝗰𝗲𝘀𝘀𝗮𝗿𝘆
Lennartl
07-20-2021 11:04 AM
