Engine Coolant Temperature Sensor #2 location?
SportsEngineer (07-16-2024)
Update: I checked the coolant expansion tank level, and noticed that it was below the min level line. I topped it off with orange 50-50, cleared the code, and then drove it for about 30 mins. The CEL didn’t illuminate again. The DTC app I use still has the P2183 code as a permanent code, and the note says the car’s ECU will clear it if it determines that the root cause has been fixed.
I’ll report back here if/when the permanent code clears.
retroren
08-10-2022 10:23 AM
georgia boy
01-26-2011 08:47 AM
