Engine Corrosion Problem
Received 3,209 Likes
I have a 2015 FType s. I had posted previously with my issues. My spark plugs were all corroded and in fact 2 broke off into the cylinder when trying to remove. 7000 dollar repair. Mechanic mentioned they have seen this before.
the reason this happens is because the hood vents in this model allows water to enter freely into engine compartment.
this is a design flaw which needs a recall and Jaguar to fix
There has never been a single reported instance of water getting in through the bonnet vents badly enough to cause this type of problem and it is obvious that the problem was caused by a slow coolant leak and odds on to be the front cross-over coolant pipe under the SC either split or cracked at one of the connections, or maybe the rear pipe.
Yes the bonnet vents sometimes let some water in but only a few drops max and nowhere near enough to cause any problems.
I would get a different mechanic as this one doesn't know what he is talking about.
Regarding Heat Retention . I really cant see how by blocking the bonnet vents it would affect the engine that much . after all that is what the fan is for and the side wing vents also allow air in and out , for example the xk 5 litre non supercharged car has no bonnet vents
#28
+1 - I was thinking about this for a while and I cannot imagine a scenario where rain would eventually lead to that much corrosion - that motor looks worse than some sitting unprotected in a scrap yard for years. I was stunned at the photos and more surprised when I saw the mileage. Even the parts of my cars that have been exposed to water like the undercarriage show nothing close to that. Coolant eating away at it does seem reasonable although it would have to have been leaking/sitting in those metal areas for a while.
Nonetheless, I’ll entertain this:
The obvious answer to your question is because people did not report it.
There is a post where a forum member removed the supercharger and it is very apparent in a photo. I have removed my supercharger and noted this. This op of this thread has it, and the video in this thread has it as well. That’s 4 data points.
There is one post where a forum member removed the supercharger (for a coolant leak) and did not have that problem.
But let me pose a question to you: How many people here have removed there own supercharger… Have you?
Do you think if someone went to jaguar to have the y pipe replaced jaguar would go out of there way to report it to them?
#30
Scrap yard cars, and your undercarriage are exposed to fresh air (allows the moisture to evaporate) and atmospheric temperature.
In this situation, the bolts have fluid being trapped/retained by the matting, and is under much greater temperature
#32
One piece rather than the older two piece with a seam which is prone to split.
I think the one piece pipe came in with MY2016.
#33
#34
#35
I have the same engine in my 2011 Land Rover LR4 with no known problems. Questions i have, has the coolant ever been changed, lifetime fluid does not get it. Themostat, water pump or even heater core. In 5 years, no spark plug changes. Even with low miles, plugs from factory don't have anti-seize on threads and plug companies might say good for 100K miles but only guaranteed for two, bosch for three. So a toss up as no known PO maintenance. I daily drive because I like them and it keeps them fit.
#36
Hi Guys
I need help, I put my 2016 Ftype in for a 52,000km (26Mile) service and while in the dealers workshop the car suffered engine failure.
This is what I found when they took off the supercharger, but they are refusing to admit this is an issue with the car.
Has anyone ever seen this or had this problem with the F-type, if so wht did the dealer do for you.
thanks
Bolts are completly rusted into dust after
entire side of the engine is ruste
thanks
#37
#38
Yep mine looked exactly the same but was caused by coolant leak
Hi Guys
thanks
thanks
I have a 2010 xf 5.0 with just on 69,000 miles and my wife had a 2013 xf V6 awd with 50,000 miles and both developed crossover coolant pipe leaks which I had replacced but it was also found that the V6 had a coolant pipe running between the V under supercharger also cracked and leaked ....... then my 2014 F-Type base model started a similar coolant leak at 52,000 mile and when we removed the supercharger it looked identical to yours including the c*^#p around the bolt heads . Definitely a problem with their plastic coolant pipes
#39
The coolant leaks that cannot be seen, wouldn't the coolant level be decreasing? If you see it below maximum and you fill to max and the level decreases then a further evaluation must be done to prevent this mess. If this is a result of coolant leak how long has it been leaking?
Frank MY16 S coupe
Frank MY16 S coupe
#40
I agree with others WOW!
From here it looks like an engine replacement. Especially if you're talking first 26,000-mile inspection.
My recommendation is if you bought new, and first 26,00 miles. would be Dealer replaces engine, contact Jag dealer area rep,
and or factory. You might want to see an attorney. If you bought used, as is, start saving for a rebuilt engine.
If Dealer clearly mis-represented mileage andor condition, and won't fix the problem, go see your attorney
One thing I would not consider doing is rebuilding that engine.
