engine oil removal info needed
Received 3,209 Likes
The plastic tube goes over the extraction tube not in or down it.
scm (04-08-2021)
the oil change was easy, i attached a pic of the 12v pump i used. it was only $15 and took approx 10 minutes to empty.
i dont think the evacuation tube is 9mm as stated earlier.
my 9mm was way too big, luckily i had some random pieces of small tubing and was able to adapt it to fit, i would say its more like 5 or 6mm
The following 2 users liked this post by scm:
JacksonvilleJag (04-09-2021),
schuss (04-12-2021)
And yes, for all you mob carrying on above, I am in Adelaide South Australia and I was fast asleep during the "debate" over my location (and gender - I'm a he).
I think you are confusing internal diameter with external diameter. The extraction tube on the car is definitely 9 mm external diameter and 6 mm sounds about right for it's internal diameter. It also sounds like you poked the plastic tube inside/down the extraction tube which is not the correct/easy method, but if it worked for you then not a problem!
so we both need to pay more attention
lol
the hose i ended up using did in fact go OVER the suction tube, and from memory the EXTERNAL diameter was approx 1/4" which = xx mm
i hope you are now enjoying your morning coffee (after all these posts!)
lol
i just reread ur original post and i just noticed you said 9mm external AND 9mm internal
lol
lol
lol
lol
Quote: "....and the oil extraction tube is 9 mm external diameter so you want a plastic tube with 9 mm internal diameter."
Which means, translated into English, the external diameter of the car's oil extraction tube is 9 mm so for a plastic tube to fit tightly OVER that tube you want the plastic tube to have an INTERNAL diameter of the same, ie 9 mm.
But to make sure I just checked and measured that pesky car tube and guess what, I was wrong!
I got my 9s and 6s mixed up (coz I am Down Under) and it really measures 6 mm external diameter!
And yes 1/4" is close to 6 mm.
Good that you got it done even with my dodgy advice!
The following 2 users liked this post by OzXFR:
scm (04-09-2021)
Nup, see the third pic in the Amazon link.
That 90.2 mm appears to be the internal distance between one flat and the opposite corner so a little more than the internal distance between opposite flats.
I have an 88/89 mm combo tool, "stepped" so that the inner/top bit is 88 mm and the outer/bottom bit is 89 mm, and the inner part fits perfectly.
Sold Out!!!
Do you have an option for purchase of filter wrench (wench)!!
Thank You Sir, Spark-o-Matic
It says it is 89 mm so I just checked on my car and in fact it is the wider/top/89 mm bit which fits on mine and not the 88 mm bit I said before.
So 89 mm is correct and the linked one above should fit perfectly.
Edit - the listing immediately below that is the one I got: https://www.ebay.com/itm/Silver-Tone...8AAOSwtUdgEpAm which I can confirm works.
