Engine replacement for my F-Type R at 18k miles
Received 2,263 Likes
However, having said that, the lack of an indicator that one should check the gauges or maybe it flashes up a warning like the shift procedure indicator or fuel low indicator or SOMETHING to indicate one needs to take a look at an imminent problem is an omission that is very frustrating.
SWMBO's Beemer has a low oil level indicator, not that her car requires top ups between changes.
100%
Oil overfill did not cause your engine failure. The engine would have to be significantly overfilled to the point where the rotating crankshaft started hitting the oil while spinning, which caused it to aerate the oil, at which point oil pressure would drop off. You'd probably get a light for this...
Also you're assuming that there is no warning for overfilled oil... while there very well may not be; you also may not have been overfilled enough to trip the warning, because it wasn't really an issue yet.
#31
#32
