Engine replacement for my F-Type R at 18k miles
Old 07-06-2017, 07:49 PM
Received 2,263 Likes on 1,845 Posts
Originally Posted by JagRag
Why would any manufacturer build an engine without an oil dip-stick?
The vast majority of owners don't bother opening the hood to check oil levels. Never have.
Old 07-06-2017, 07:59 PM
UC3's Avatar
UC3
UC3 is offline
Reminds me of the fully electronic dash of the 1980's. It was quite the fad while it lasted, but proved totally impractical.
BMW's, Mini's, Audi's, and others have no dip stick. I guess they figure the engine should not be using oil and you should only change it when needed...like the deletion of transmission dip sticks yrs ago.
However, having said that, the lack of an indicator that one should check the gauges or maybe it flashes up a warning like the shift procedure indicator or fuel low indicator or SOMETHING to indicate one needs to take a look at an imminent problem is an omission that is very frustrating.
Old 07-07-2017, 09:39 AM
SinF's Avatar
Received 2,141 Likes on 1,461 Posts
I blame Mikey, the whole thing is entirely his fault.
Old 07-07-2017, 09:57 AM
SWMBO's Beemer has a low oil level indicator, not that her car requires top ups between changes.
Old 07-07-2017, 10:17 AM
mbelanger's Avatar
Wait...a customer is allowed to actually OPEN the hood? And it doesn't void the warranty? The hell you say...
Old 07-07-2017, 11:00 AM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
The Gen 1 & 2 MINIs have dipsticks, but the Gen 3 don't anymore? Sad.
Old 07-07-2017, 11:18 AM
Dogbreath!'s Avatar
My SLK didn't have a dipstick (except for the one behind the wheel). My wife's C63 does. Go figure.
  #28
Old 07-07-2017, 12:51 PM
JagRag's Avatar
Old 07-07-2017, 08:03 PM
Funfactor's Avatar
Originally Posted by Stohlen
100%
Oil overfill did not cause your engine failure. The engine would have to be significantly overfilled to the point where the rotating crankshaft started hitting the oil while spinning, which caused it to aerate the oil, at which point oil pressure would drop off. You'd probably get a light for this...
Also you're assuming that there is no warning for overfilled oil... while there very well may not be; you also may not have been overfilled enough to trip the warning, because it wasn't really an issue yet.
I have a 2016 Type-F R AWD, the dealer overfilled the oil by 1 gallon....yes I said 1 gallon and there was NO warning light. I caught it by doing what the owner's manual said-check the oil level every week.
  #30
Old 07-07-2017, 08:49 PM
Mulmur's Avatar
Wow, at that level I would wonder that they vacuumed out all the old oil?
Lawrence
  #31
Old 07-07-2017, 08:58 PM
Ah ha. I think I'd rather sit listening to some music waiting for the oil level to settle than rooting around under the hood getting dirty.
I wish my cars had no dipsticks.
  #32
Old 07-13-2017, 08:45 AM
daily_jag's Avatar
When I check my oil, most of the time I get the "unavailable" message. I know that the engine has to be warmed up and then allowed to sit for a period of time for it to read, but it would be nice if it said "Available in xx minutes" or "Warm up engine first"
