Engine ticking sound on start up
My issue may be different but here's what I know: these engines have always been loud at startup, and always sounded sort of like a diesel due to the direct injection system. If you open the hood there will be a pronounced tick coming from the injectors; this is normal. My ticking noise can be heard over the engine when driving and does decrease as the engine warms; but does not go away. It sounds very similar to shaking a salt shaker in perfect rhythm with the engine, increasing along with engine rpm.
If this sounds like you, take it in. If it sounds like just the injectors you're hearing, don't worry about it and just mention it during your next service.
And that's what was replaced the first time (entire supercharger) I took it in for this noise. And while the supercharger was apparently bad, it did not fix the noise.
Not an issue if the ticking goes away within 5 minutes of starting a cold engine.
#28
That ticking noise always bothered me and I have mentioned it several times to the service rep. They would always tell me it was due to the DI and not to worry about it. Even pulled an XJ and an F tYpe that were in the service bay and they all made a similar noise. I recently had to a coolant leak and had to remove the top end of my engine to get to the pipe. In the process, the water pump had to be removed, so I decided to replace it. Didn't notice the change until a few times getting back in the car and the ticking noise is completely gone !!! so F-Typical's assertion about it sounds like a belt driven component seems to make sense in my case. The water pumps are a known issue with our engine in both 6cyl. and 8 cyl. forms as there have been several redesigns and updates to the water pump over the years. thoughts?
F Pace V6 S - Ticking
A recent purchase of 2017 F Pace S and as Stohlen described very well, a ticking or tappety noise experienced, "a salt shaker in perfect rhythm with the engine, increasing along with engine rpm", this constant and irrespective of engine temperature and car is at 28k miles. Car was in Jaguar service centre last week and technician echoed what we have heard here before that this a standard noise with the fuel injectors on the 3.0 supercharged engine. Interesting then that Cherry states that this rectified with water pump replacement.
I wonder if anyone can corroborate if have pump was proven to be the issue?
Cynic in me wonders whether this work is not cost-effective for the dealership, any thoughts?
I guess key point is whether there are any cases to share where Jaguar [or independent] acknowledged this as a problem, rather than a characteristic, and made good successful repairs?
many thanks
Mark
many thanks
Mark
#30
chris.schneider (09-07-2021)
#32
yea i get the same thing...took mine in to get it checked out and the dealer says "normal" so..... i guess it's normal but sounds concerning to me.
#34
#36
Glad I found this thread! I've the same engine "salt shaker tic" in my 2016 F-type S Convertible. I've only had the car a few weeks which I purchased from Carvana.com. Last week I took it to Jaguar Ocala to get it fully checked out ( also for things like software updates for ECU & TCU etc... ). I did tell them about the ticking sound before they checked everything out. Once done, they said all was well, but they did clean the fuel injectors as they acknowledged the ticking sound and they wanted to smooth out the fuel pressure flow, and they added some injector cleaner to the fuel tank. I drove the 170 miles home, and days later the ticking sound is still there ( for sure when I start it ). I've been SO worried about this because the car came from Carvana.com and I drove it 180 miles home only to find out that the oil level was showing "Oil Over Filled!" when I checked the oil in the computer, which we all know is never a good thing in these engines ( there were no warning lights just to be clear ). I took care of that right away but it left me worried about any damage from oil overfilling.
Thanks to this thread, I'll be sure to park the car when I get home today, and with the car running and I'll check to see if the ticking is still there or not with everything warmed up... wish me luck!?!
UPDATE: I did check once I got home ( about a 30 min. drive ) and I did still have some ticking at idle though not as much as a cold startup.
Viking_Quest
10-10-2023 12:12 PM
philc850
03-30-2016 09:45 AM
