Eurocharged Tune and Pulley Sale.
I wish my results from Eurocharged were anything to brag about. on my 4.2 supercharged 08 xkr I gained 7whp max and no improvement in daily drive-ability . I requested a refund, but they would not refund entire amount, even though at least 24hp gain was promised.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
We have two vendors on the F type forum who are known quantities. I would stick with them.
I have the VAP tune on my F-Type but I did have the Eurocharged pulley and tune on my previous XFR and was happy with the dyno results and they were not at all difficult to work with on my endless pre-purchase questions, so I'm sorry AlexJag that you were disappointed.
I went with VAP this time as they had a greater number of F-Types under their care, not as a result of anything intrinsically negative about Eurocharged...
i would be looking at your car as if it had a fault or faulty component .
e.g. maf . iat2 , cats or the likes .
probably not to do with the tune at all by the sounds of it .
what was your bace line dyno and afr's & fuel trims like before the tune ?
#30
if everyone else is getting around 24hp gain and you got 7,
__________________
#31
And AFR is suuuuppeerrrr rich!
Datsports (06-07-2017)
#32
it kind of backs my theory . it was running way too rich before the tune .
and exactly as rich afterwards .
id be looking at your maf . check your g/s rates .
the tune certainly done the trick as far as improving torque and shifting the torque to an earlier point . so ill bet if the AFR was fixed both stock and eurocharged tune would befit from that .
also agree with stohlen the advertised gains are not always peak gains , as you can see at around 5200rpm on your graph . you had more than 7HP gain at that point .
same goes with the claims on pulley upgrades . they are not peak claims .
#33
