Exhaust Lacking on 2019 F-Type R Convertible! Any help?
#82
Hey everyone,
Just thought I’d give a little more info on the 2019 issue that some will unfortunately encounter.
Basically in 2019, Jaguar started using a Bosch Flexray MED17.8.32 ecu for the F-Type. Previous to some date for 2019 F-Type model year, Jaguar was using MED17.8.31 (which is non flexray). The non flexray ecu came in play around 2013 and ran on every 3.0/5.0 JLR till 2017.5, at that date is when LR started using MED17.8.32 Flexray.
The F-Type ended up being the last 3.0/5.0 JLR model to not fully adopt into this flexray ecu. Most of the JLR vehicles had fitted the flexray ecu by 2019 model. So you will find 2019 model year F-Type’s with either a MED17.8.31(non-flexray) and/or MED17.8.32(flexray). I’ve gathered a large amount of VINs to know which JLR model is flexray, except for F-Type being fresh into this crowd for 2019, I don’t have an exact VIN break yet for them..
For the flexray cars, there’s 2 widely different versions. The early flexray ecu’s commonly found on all JLR 3.0 and LR 5.0 are easy to add in pops and bangs, for the newest release flexray ecu found in 2019 JLR 5.0 has not been fully tested to adopt pops and bangs. It’s not that we won’t be able to make this happen, bluntly it’s just I’ve not had a test mile to get this resolved...(the 3.0 doesn’t seem to have this flexray newer version but I’d imagine it’s just a matter of time)
What makes the matter complicated for the “flexray” cars, there’s no actual protocol to read the file off the ecu through OBD(unlike the previous non flexray MED17.8.31 which could be read). The tool we commonly use for flexray is from CMD, this tool ONLY looks at your ecu calibration number(a function any scan tool/code reader can view), then searches CMD’s server for a matching stock file for me to edit..this is called a “Virtual Read”. Which also means if there’s no matching file in CMD’s server, that car is sadly S.O.L to get tuned over OBD until an available file is posted. The only option at that point (as of current date) is to bench read the file from the ecu via a tool in our shop or at one of our dealers. However if the CMD finds a matching file, that file is encrypted and sent to me for editing. The CMD basically mirrors the dealers SDD2 flash function, which means it can only flash/write the ecu.
I know for some 2019 owners it’s a buzz kill, unfortunately it’s just another day in the tuning world. We’ll get it all resolved, but no eta at the moment.
#83
No block on flashing. We can and have flashed multiple 2019's.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Unhingd (07-29-2019)
#84
It's weird that the V8 lost nearly all the crackles and pops as it's not the case for the V6.
I have a German P340 MY20 and while it is a bit quieter on start up and especially idle (due to that damn particulate filter even pressing the exhaust button makes nearly no difference on idle) the soundtrack is nearly the same when you are driving it. It still pops like crazy and you can still extend the pops if you keep tapping the pedal.
I agree that the old V8 was a beast though, you can't really compare the V6 crackles to it.
#85
#86
The particle filter fitted to JLR petrol vehicles is something we're curious about, there's no information about it in North America (nor pics). I've checked the North American version of Topix and no information about it, seems like something only being fitted to Euro6d and Euro6d-Temp compliant vehicles in ROW market.
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic170389_7.gif)
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
#87
#88
That's weird, so even when you are above 3000rpm and holding the gear you don't get anything when you are tapping?
Personally I only noticed that you can't do it forever, at least, if you are trying to get the pops in the same gear they will stop eventually, changing gears back and forth helps though.
#89
And how hard you do it doesn't make any difference - It used to be a light feathering on the gas - but sometimes I've tried it hard enough to induce mild whiplash.. <LOL>
#90
#91
This isn’t a MY19 problem cause light taps gives me what I consider a machine gun sound very easily , do you have a video of the “ explosive backfire” from the older car? Maybe our definitions are different? Dealer has looked into this?
#92
I don't think our definitions are different. It sounds like your car is different than mine... Perhaps it has something to do with some of these having a different tuning protocol per VelocityAP?
And yep - I spoke to the dealer in SC where I bought it from, as well as the local dealer in Indy who confirmed:
I got an answer from my guy in Mahwah. I appears the best we can do with the exhaust feedback is by using the Dynamic/Sport Mode. The fuel necessary for the back-talk apparently got us in Federal Emissions hot water.
#94
Hi all. I have a 2019 F-Type R coupe. I recently upgraded from a 2016 F-Type R. I completely agree with the OP. The noise difference is night and day. The pops and bangs are all but gone. You can't coax any out, and worse still it's just overall a much quieter system. I looked at the parts numbers, and the back box and mid section of the exhaust are the same through 2014-2020, however the cat/particulate filter did change and I am wondering if that has something to do with the noise change, along with the different ECU?
Crucially, has anyone got anywhere with making a 2019 R sound like a 2014-2016 R? I need to fix mine as it's just depressing!![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#95
Ah so the 2019 R does have OPFs?
I'll be sure to drop them a line. I have bought bits from them before. My primary concern is the warranty, but if the 200 cell sports cats don't always throw engine codes I could live with that. I could always swap them out if something went bad. I'm mostly concerned about getting the loud roar back. The pops and bangs are amazing, but that's only going to come from mapping and that scares me should anything go wrong down the line.
Thanks!
Thanks!
#96
If you tell about the 2019, here in Europe its more the MY2020 (L in VIN on 10th place). Because I have the same. Now for the new slot-eye 2021 things could even become worser as they wrote in the description : "Both V8 engine options get a Quiet Start function that keeps the active exhaust valves closed for a more subdued sound until the driver really gets on the throttle." Means that if you open the valves manually, if I understand, they will keep closed as long as you dont have the rpm. Minimum this is not the case on mine.
#97
Received 3,226 Likes
#98
#99
OPF/GPF is just german/english for the same. This is the new WLTP norm now obligatory for new cars. The down-side is the sound reduction for the moment as tuners dig in.
But believe me, Golf's and BMW's have much more problems with this issue as BMW dropped M3 as example. The hudge V8 Ford is much less affected and when I push the valve button in idle the difference in loudness is very notable. So I am not so much worried.
That's the bad, but the good is that in the near future all non-WLTP cars risks ban from certain cities and areas. In the case you have such earlier car, you stay owner of scrapped aluminium. For the moment in Europe, but Trump is also not there for ever.
Reading the M21 valve issue, they wrote : "This ensures that the electrically-actuated bypass valves in the rear silencer remain closed until automatically opening under load" So it seems that some springs will not allow the opening under low rpm or idle even if you change mode or press button. To confirm we need a new owner.
#100
