Expecting 11 sec 1/4 mile on V6s?
Hi Guys.
I have a convertible F-type V6S.
I will run this spec next spring.
dual pulley upgrade with viezu tune (suppose to 495hp)
Full intake kit from Mina Gallery
200 cel Downpipe
I run 305 michelin super sport in rear combine with a LSD diff.
I'm a good drag racer. I been on track at 16 years old and now im 35.
I really wish to reach 11.9x sec.
Someone have already made it on a track with a slip?
Thank you
200 cel Downpipe
Thank you
Wortec two piece brake rotors, replace lead acid battery with a LiPO unit (Antigravity), and most good forged wheels (like BC forged). I think the battery alone is at least 30-40 lb. If you search for threads about each of the items you will find the associated weight savings.
The Wortecs save about 40 lbs and the VS Forged wheels save 40 lbs. I’m trying to remember what else I’ve done to account for the other 30 lbs.
Probably only a pound or two each, but those are not in either of my weights. I did have a 5 lb weight saving with the aluminum crank pulley and several pounds of air boxes when the Mina Intake was installed. A few pounds on the VAP exhaust and that 1 pound on the engine cover. Maybe it all adds up.
The battery is closer to a 50lb weight saving. I just looked at the scale tickets again and the actual total weight reduction was 160 lbs. (3640 vs 3800 fully wet).
Row_ca
06-27-2024 05:36 PM
ImNotFamousAnymore
09-02-2016 02:00 PM
