F-type adaptive dynamics fault
Hi guys,
I lowered my 2014 F-Type S of 30mm (H&R springs) and now I'm getting the adaptive dynamics fault. Along with it, special modes do not work. Does anyone know if adaptation via diagnostics is needed, or how to solve the problem?
Thanks in advance for the ideas.
Make sure the ride height sensor arms are not broken and are connected. Many reports in the past about them getting damaged or disconnected during spring change or suspension work.
Carbuff2 (05-11-2024)
The (probably) strange thing is that only when the ignition is switched on, no error lights up and the sports mode can be switched on. Everything stops working after start engine. Disconnecting the battery does not help..
EDIT: sensors in the front? I'll check it, but adaptive is rear only..
STICKLER (05-10-2024)
ftype_rocket
04-02-2021 11:41 AM
