F-type Bonnet problem help!
Hello,
Today i opend my bonnet to check something but when i wanted to close it again drama happend......
i closed it like they write in the books (both sides even pressure down) but now when it sits all crooked!
and i can't open it again it only unlatches at driverside (Left) the right one is stuck!
Somebody has any solution i tried almost everything but nothing worked
regards John
regards John
Michael P 1989 (07-05-2023)
I would first check to see if one side is not latched then apply pressure there to close.
Perhaps once both sides are latched it will unlatch.
I did have something similar once.
Still trying to work out best way to close the bonnet.
The manual seems to indicate pushing evenly on the front with hands about 2 ft up and about 3 ft apart in the center.
That takes quite a bit of pushing.
I have also closed it by pulling down hard from the center back.
All seems a bit cloogy, especially given the relative flexibility of the aluminum!!
Plus pushing on the front center leaves hand marks on the paint finish.
thanks for the reply,
i know what you are saying only my problem is a bit different.
when i pull the lever to open the bonnet it pops (on both sides)
but only the left side is loose the right side seems loose only it isn't (some kind of windhook) it moves a little bit but not all the way
so i am clueless tried pulling the cable more with a plier but didn't work either
regard John
regard John
regard John
regard John
DC
eeeeek (07-05-2023)
Received 3,226 Likes
homerlikebeer (07-05-2023)
BOY, that new-car bonnet was difficult to close. I needed to give it quite a bit of 'momentum' to fully latch. If I had needed a third try, I would have climbed onto it in desperation.
Ours drops fairly easily (latches are well-lubricated), but at a recent Jaguar meet a new F was on display. OF COURSE I wanted to look under the bonnet.
I opened the hood on a 2021 P300 on the showroom floor. The hood opened really easily and when I closed it I slammed it a bit as it closed with very little effort. Mine takes a little bit of a shove to close. I suspect the new one may have had different struts on the hood than mine.
Did you sort it?
Hello,
regards John
regards John
Did you manage to sort this? The same thing has happened to me.
Michael
