F-Type Dead as a Doornail
Greetings, All. LTNS!
I went out this morning and found my 2016 F-Type stone cold dead. Won't start, no accessories working, and it won't talk to the OBDC.
Rear hatch won't open, Glove compartment won't open. Door locks don't work - I found the car unlocked, but I think it unlocked itself. Pretty sure I'd left it locked. Tried using the remote, and the Android App - no luck with either.
The car gave NO indication of any problems in advance. I was driving it yesterday, and everything was fine right up to when I parked it. Before I tear into it, or call the shop, I just wanted to check on here in case there's a quick fix or diagnostic anyone can suggest. I did check the fuse (F17) for the Engine Management System and it looked OK.
HELP! and TIA,
Jim
HELP! and TIA,
Jim
If it's unlocked, pop the hood and check the voltage at the jump start posts if you can't get into the trunk (not sure if there's a key slot in the trunk for the emergency key?). If you get 0 volts there, or 12+ volts, something other than just the battery is likely going on, but if it's low volts, battery is most likely the culprit. If that's the case I'd also try jump-starting it then checking voltage to make sure the alternator is putting out 12+v too.
Received 3,209 Likes
Reads like you are able to open the door and get into the car, in which case you can open the hood and access the charging points.
Then hook up a decently powerful battery maintainer (not a charger as they can damage the electrics) to those points and leave it going overnight.
This should "repair" the battery enough to at least open the hatch and maybe start the car, and if you are really lucky it might even completely "fix" the battery, although a completely drained battery usually doesn't fully recover.
I believe the CTEK won't actually charge if the battery is completely flat. Other maintainers may, or may not, exhibit the same behaviour.
Not sure why it would have drained overnight unless you accidentally left something on. If it was an old battery it will die fast. Hopefully it is the battery. Cheapest fix. Good luck.
That's interesting as the underhood points are the Jaguar recommended way to do it. Probably because it's easier to open the hood with a dead battery.
By any chance did you plug in a obd2 code reader before hand? I did this with mine before and had the same issue. Something about the power modules having to be reset after plugging in a code reader. After recharging the battery I disconnected it for about 10 minutes and reconnected it. No problems since.
Roadan
07-31-2016 08:45 PM
polarisnavyxj
06-07-2016 05:11 PM
