F-Type engine break in
i remember back in the 60's and 70's my dad telling me that new engines have to seated properly and not to exceed 3000rpm for the first 1000 miles, since this is my first new car in along time, have 200klms on it, my question is, is there Jag recommended break in period?
There is a break-in period. However, there is a typo in the manual (highlighted in green below) under the breaking-in instructions:
The vehicle is built using high-precision manufacturing methods, but the moving parts of the engine must still bed-in relative to one another. The process occurs mainly in the first 2 000 miles (3 000 km) of operation.During this breaking-in period of 2 000 miles (3 000 km):
- Avoid frequent cold starts followed by short-distance driving.
- Preferably take longer journeys.
- Do not fully press the accelerator pedal during starts and normal driving.
- Avoid continuous operation at high engine speeds and avoid abrupt stops.
- Do not participate in track days, sports driving schools, or similar.
- Drive at varying engine and road speeds. Do not exceed an engine speed of 4 500 rpm (revolutions per minute) and a road speed of 105 mph (170 km/h).
- Engine and road speeds can be increased gradually.
- Engine speeds in excess of 5 000 rpm should only be used briefly, e.g., when overtaking.
- Do not exceed 4 000 rpm until the engine has reached its full operating temperature.
- Avoid laboring the engine by operating the engine in too high a gear at low speeds.
I would add that it is a good idea to drain the factory oil and refill it with the proper factory specified oil and change the oil filter around the time it is broken in. I did mine at about 2750 miles.
I assume that you qualify for the free annual scheduled maintenance which includes oil & filter changes, but you don't want to wait a year and however many miles that you will accumulate before changing out the original oil. There are lots of very helpful threads here regarding how to do an oil and filter change and if you are at least slightly mechanically inclined, it is an easy process with a Mityvac extractor. The cost for the oil and filter is usually under $130. Just be sure you keep your receipts and use the proper Castrol Edge Professional EC5 0W-20 weight oil. And/or buy the oil from your dealer's parts department.
The last time I bought a quart they gave me the VW/Porsche 508 CO/509 spec. approved Castrol Edge Professional 0W-20 oil as the EC5 formula which meets Jaguar/Land Rover spec. STJLR.03.5006 seems to be discontinued. The VW/Porsche oil is close enough in formula to be completely interchangeable.
uncheel (02-15-2024)
I would concur with all of the above. Allegedly, there is enough precision in today's engine manufacturing that you don't have to do the first, quick change that Dwight suggested. I may be old school (with a Doctor of Motors certificate to prove it), but totally agree with his recommendation. Unfortunately, JLR won't cover the cost of an early oil change, but I think it's a nominal investment to get your new toy off to a healthy start for a long life. Last I knew, both Castrol Edge Professional EC 0W-20 and Millers Oils XF Premium C5/C6 0w-20 Fully Synthetic listed the JLR spec, but there are others. I've been getting mine from www.fcpeuro.com
Dwight Frye (02-16-2024)
polarisnavyxj
06-07-2016 05:11 PM
