F-Type Front Lowering Springs DIY
Hi Group...
After publishing other DIY articles/documents on this forum, I thought I would continue as I do mods to my car, to the extent they are useful and/or helpful.
As mentioned before, modifying cars is my relaxing hobby. I enjoy learning about them and modifying or fixing them. For the last number of years, I have been doing that in the Porsche and BMW forums/communities,
so I thought as I continue to modify (play) with the F-Type, I would document some of those items here as well.
I recently installed lowering springs, with quite a few challenges noted HERE. I took some photos and documented the process, and put them in my DIY template. I have attached the FRONT process, and will likely get the REAR posted soon...as time permits. As mentioned, the Porsche forums found these useful so I continued to produce them. If not useful, I still photograph and document for my own records.
I eventually was able to get the proper VAP springs installed and the results were exactly what I was hoping for. (Read the link above and you will understand )
NOTE: These are created in the spirit of helping others. If you have a better way of doing it, knock yourself out!...this is simply what worked for me.
DC
DC
The following 9 users liked this post by Therock88:
Carbuff2 (01-08-2022),
DJS (06-14-2020),
JacksonvilleJag (06-15-2020),
madmax1911 (06-15-2020),
Mbourne (06-17-2020),
and 4 others liked this post.
I never have a helper, but that will make re-inserting the struts into the towers go much bettef/quicker, especially the rears.
Good luck,
DC
Sparky H (12-28-2020)
At 69k miles, mine still looked good so I reused them. I had also marked them with sharpie to maintain the same alignment and torque for reinstallation.
Good luck,
DC
The H&Rs smoothed out the ride a bit as well, but the drop may be too extreme for most folks.
