F-Type Front Lowering Springs DIY
So i got the rears installed, the left side is making a clunking noise over medium bumps. No noise over small bumps. Car rides otherwise perfect even without the fronts installed, I'm guessing the left spring wasn't seated properly so it loosens on rebound making the noise.
The drop gradually settled over two days, before was about 2.2inches from fender to top of tire, after is about 1.3inch from fender to top of tire, not scientific I know, but falls right in line with VAP's 7/8'' figure. Very happy with the result so far.
Getting fronts done on monday, hopefully it doesn't take much to fix the noise.
Good luck,
DC
Just reporting back my impression of these springs, finally got all corners done.
It is a resounding "great", ride is definitely not harsher than stock, corners flatter, rebound is quicker, comfort is improved, even steering feels better, especially the return to center(what's the technical term?) motion is smoother and more linear now.
I will definitely recommend these if anyone is on the fence.
fence like I did.
fence like I did.
Suspension Spring Insulator T2R15835
fence like I did.
fence like I did.
#28
#30
fence like I did.
fence like I did.
#31
Good to hear! I am seriously considering these lowering springs. My only worry is that I'm in Philly and the roads are horrible around here and also outside the city. Is the drop going to be an issue considering the car is already pretty vulnerable at its current stance?
DC
Ducatista83 (03-25-2021)
#32
You will know if you can't clear something, when you see it.
If you are talking about the ride quality, I can assure you it is every bit as good as stock, maybe, just maybe, a tiny bit better even. I haven't had to use the whole suspension travel yet, though I'm positive it is that much shorter than stock, but in that scenario, I'd be more concerned about my rims.
I have yet to encounter those plastic cover they use during road work, the ones they cover their equipment power line with, they are a huge bitch since even if you can clear it, the drop is so sharp you will compress the suspension and drop your frame right on top of it, avoid at all cost!!
#34
I'm in NYC and the relatively conservative drop of 7/8" hasn't been a problem. I do encounter scrap issues where I wasn't before, but it is limited to the front sacrificial lip under the front spoiler. My driveway for example is quite steep, if I go head in it will scrap the lip every time. If I went butt in then it will scrap on exit.
I have yet to encounter those plastic covers they use during road work, the ones they cover their equipment power line with, they are a huge bitch since even if you can clear it, the drop is so sharp you will compress the suspension and drop your frame right on top of it, avoid at all cost!!
#35
#36
Thank you once again for the DIY Rock, you're a pillar in the community.
Observations:
Rears were much easier than the fronts for me. Not sure if I did something wrong, but I really had to unreasonably wrestle the upper control arm on the fronts. Also used a small scissor jack against the sway bar to expand the suspension downward to get enough clearance. Additionally, I found it basically impossible to re-align the rear struts with the shock tower bolt holes, since from below you are going in blind. I had my dad help me with this while I sat in the bare trunk and made sure the shock was aligned properly. Overall, the same basic concept but more obstacles and thus harder than coilover installs I've done on some JDM cars (G35, etc).
Tip: The rear lower strut mount bolts seemed to be around 21mm, which is larger than most socket/wrench sets since they top out at 19mm. I had a 23 wrench lying around and this worked, but I was very careful to not strip the bolt head as it was too large.
I installed Eibachs, imo they ride the same as far as stiffness but I feel a little more road feedback, especially on low quality roads. I would say about 20% more. The springs definitely appeared to be less progressive than the OEMs. Side note, I miss having colorful springs that you can see through the wheel (Eibachs are black, and I'm coming from bright green Teins lol).
The look though, complete with spacers, is really what I've been after for a year now. The Eibachs drop .6in/1in and I appreciate the increased drop in the rear to even out the perceived stock rake. Although, I would probably appreciate another quarter inch all around, but my scraping days are over so I am satisfied
Observations:
Therock88 (01-08-2022)
watson6505
11-28-2019 12:03 PM
andrew0068
10-09-2019 04:45 PM
