F type that has heavy intermittent thump when driving. Help??
Hi I’m a virgin poster
have an f type that has developed a heavy intermittent thump sound when driving. Not engine and jaguar house have it and can’t find what it is either. Not related to speed but must be moving. Can make the sound when slowly turning as well as driving straight. Is particularly prone when on uneven surfaces. Seems that the usual stuff is out given Jaguar can’t find it themselves. Any ideas? I’ve seen a thread about the way the body work connects together but not sure whether this was idle chat
regards
Shaun
regards
Shaun
David Meier (11-15-2019)
Re heavy thump on f type
Thanks for speedy reply.
jaguar have had car for 24hrs now and they still don’t know what it is. I would have hoped they’d checked suspension, struts and engine mount but hey I’m up for getting on the phone and asking. There are a few threads relating to extraneous noises which do mention engine mount, soft top hood rattle and something to do with a bodywork connection failure but not sure whether I dreamed that one up! Thanks I’m going to call now
regards
Shaun
regards
Shaun
Guessing the engine mounts/cross support bars. I had the same issues with a "thump" and found the T50 (I think) star bolts holding the support bars on top of the engine bay nearly loose enough to turn by hand. It's an easy check if you have a T50 Star Fitting and you can do it yourself. I would add some industrial thread-lock and tighten them down if you find that to be the case. I check them now and then when I have the bonnet up.
STMPY (11-15-2019)
ian1972
10-16-2012 12:32 PM
