F-Type Jacking Points Exact Location
Yes, I think the final consensus and what I did was to use the area portrayed by your blue box w/ a hockey puck or something to keep the head of the jack from gouging that area.
You could also use the ridge between your blue and black boxes, if you had a hockey puck carved out as in post #13.
The following 2 users liked this post by Foosh:
CaptainHam (01-25-2016),
Unhingd (01-25-2016)
You didn't mention the REAR lift. On my R, the reinforced jacking rail is located further inboard than the front rail, adjacent to a support plate. I lift from inside of the "triangle" area surrounded by the three fasteners that are holding the support plate (a modified hockey puck works here).
BTW, no need to ridicule anyone who tries, right?
The following 2 users liked this post by deltagroup:
CaptainHam (01-26-2016),
Panthro (07-15-2017)
deltagroup (01-25-2016)
I did ask about the front at the time, but he just gave a casual "It's marked with an arrow", which I accepted; however, on subsequent inspection, I wasn't so happy until checking with you guys!
I still have a painful memory of crushing part of a previous car trying this once, the area I chose looked like a solid support/frame but turns out it was made of butter, so that didn't end too well for me!
Thanks both, much appreciated.
The following 4 users liked this post by Tel:
Thanks Tel. Yeah I saw that on one of the other posts I found here when I did an initial search. Very informative, but at the same time it wasn't reassuring enough for me...I wanted to make sure I was millimetre perfect so I didn't go crushing the underside!
#30
#31
#32
OK. I've got the jacking points down from this thread. But what about where to place jack stands once the car has been lifted with a floor jack? (Not all of us have a lift in their garage like WaltB.)
On my other cars, I've been able to ID alternate jack points for the floor jack which was out of the way enough to place a jack stand at the OEM jack points OR place the jack stands at major suspension support parts (eg, inner lower control-arm joint/knuckle).
TIA for any assistance.
#33
#34
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1280x960/rear_jack_point_bae2b2f02becfbc843fc75b57b586b6622b99cbf.jpg)
#35
In the front, a plastic "skid plate" covers what I expect is the front cross member that should safely work as the front jacking point. But, in the rear, a transverse support member between the radius arms (Careful--those guys bend!) does not appear sturdy enough to serve as the rear jacking point. So, short of our knocking on WaltB's door (j/k Walt), perhaps someone can share a safe lifting point for both front and rear. Anyone?
sonny2 (02-06-2016)
#36
Yellow arrow marks the "lip" that you'd slot into with a portable jack (they probably have a better name than that), the red rectangle marks the area you can use a trolley jack on (on the black support in between the 2 exposed bolts).
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/588x441/jacking_points_rear_a0d1e2b35daafc76660e5daebf30139c9c58d9dd.jpg)
The following 5 users liked this post by CaptainHam:
caunyd (02-10-2016),
deltagroup (02-06-2016),
Mbourne (02-06-2016),
mjm3457 (02-06-2016),
Panthro (11-10-2017)
#37
My question, Captain, is where to lift both front (or both rear) corners off the ground at the same time rather than lifting one corner at a time. Lifted thusly, a jack stand can be safely placed at each of the two front (or rear) pinch moldings (lips), as you suggest. IOW, I'm interested in lifting the entire car off the ground, not just one corner.
Lifting and placing a jack stand one corner at a time can be risky if the intent is to lift the entire car. I say this fully admitting that in my distant past, I did just that. While it can be done depending greatly on the capacity and height of the jack stand, I would caution against it. So, if I'm unable to identify safe front and rear lifting points, I'll likely go with a couple trolley jacks positioned on each corner (front or rear). This I've done before though it takes longer.
#38
My last post was in response to caunyd's request for clarification on the individual rear jack points, for single wheel removal at a time. Now that bit I could at least assist with.
#39
#40
Received 3,226 Likes
It is a picture of the XF V8 (S or R) axle stand points, you can tell it is an XF and not an F-Type by the shape of the rear mufflers.
Also, these are the XF axle stand points and not the jacking points, the jacking points are outboard of these on metal ridges.
zmoothg (11-22-2016)
