An f-type that lost its soul - exhaust note problem
Your reasoning for this thinking would be greatly appreciated and perhaps helpful for others considering a tune.
My experience with my V8S - K309 muted the exhaust, lost all pops and crackles. K309v2 restored full soundtrack.
Took car in for service last year and they updated the software to the latest versions. Lost all pops and crackles and exhaust sounded muted again. Wasn't able to get them restored this time. Have since sold the car.
Read and Clear Fault Codes (the error code was CHCM U2011-71)
Diagnostic Allowance
Configure Existing Powertrain control module
Software download Chassis Control Module
Below this the verbiage says the CHCM and PCM software was updated.
I gotta get my pops/crackles back
Received 3,259 Likes
I brought MY18 F-type in for a leather seat issue but had them fix the spoiler (which would intermittently just stay deployed). Turned out to be an issue with the software of the "Chassis Control Module". No clue what that is, but when I got the car back it now has this same phenomenon where the Dynamic mode is reset after every ignition vs the previous 6 hour retention. I'm also thinking it's not popping as much. Would the paperwork say that they upgraded the O2 sensor? Mine says:
Those pops and crackles are caused by the PCM software telling the injectors to squirt some fuel in on the exhaust stroke which then ignites in the exhaust pipes.
Very naughty now under CAFE/emissions/noise regs so it's been neutered.
I used to get paranoid whenever I took the car in for the annual service, always warning them not to apply updates. Not so finicky anymore. I really don’t care what they do to the OEM tune anymore. I always make certain that’s in the car whenever they have it just in case they go wild with the SDD.
Why should the car not pop anymore due to regulations when others still do? Yes, because of the new particulate filters in Europe all the new cars, even Ferraris or Lambos, don't sound as good and extreme as before but they are still pretty loud and do pops and crackles, although they are a little bit muted. The same applies for a C63 AMG, it's still really rad and was only castrated a little bit, not as much as on the F-Type V8 which seems to nearly has lost all its pops and crackles?
#28
#30
I have a Canadian 2015 V8 S that has lost it's crackles and pops. I am not really interested in more power; however, if there is a power bump then I will 'reluctantly' accept it.... The warranty is done and I was thinking of getting a tune to return the pops and crackles. Any suggestions?
#31
Would you say the VAP tune has more fireworks than the stock tune did (before they killed it with the updates)? Also, does the tune keep the concepts of the various modes: regular, snow, dynamic? And does it allow for the default ignition start to be dynamic mode?
#32
1. OEM tune
2. most recently dyno 'd tune (early version)
3. updated tune, all features left intact
4. updated tune, shift indicator disabled
5. updated tune, shift indicator and ECO stop/start disabled.
I am running tune 3 . The updated tune evened out the throttle response, making power application far more precise.
#33
I've only had the car back for a few hours, but it does sound better. I can actually force the pops/crackles like I was able to do before by laying off the accelerator -- a phenomenon I wasn't able to do before the "hose" was reconnected. So, it appears that they may have solve my problem. Wanted to share this with others -- not sure if they were the ones that disconnected the hose (by accident) the last time I was in -- but either way, happy to have the soul back in the car
Mahjik (07-31-2019)
#35
Ok -- so here's an update. I happened to be back at the dealership doing an (overpriced) oil change -- I mentioned the missing pops and crackles. The tech noted the following: "found rear left muffler control chamber vacuum hose disconnected. Refitted hose and checked open/close operation -- working fine". Just to further complicate matters they also found that I needed a "Powertrain Control Module update" ... again ??
