F type overheating problem (dashboard)
Hello everyone,
I would like to ask you regarding overheating engine problem in my Jaguar F-Type. When I start driving faster about (100-120) km/h in the dashboard appears a problem (link attachment). When I start driving slower temperature arrow is going down. While I drive long distances this problem appears and arrow go up and down up and down (link attachment). My services has changed coolant capacity with sensor, but problem has not changed. Maybe you guys had the same or similar problem? Situation is badly because the temperature rises till maximum RED level (link attachment).
Car model: F-Type 3.0 340AG 2015 year /70000km.
LINK- https://drive.google.com/open?id=1NH...NP30dWtIIpqE9T
For contacts:
Gmail: REMOVED by GGG
Mobile phone number: REMOVED by GGG
For contacts:
vijurkas22 (04-18-2020)
I would try replacing the thermostat. If it sticks closed, the engine coolant will not circulate.
I have not replaced one in the F-Type, so I don't know how hard it is to reach, but its usually an easy DIY.
To troubleshoot for free, you can always remove the thermostat from its housing to see if that fixes your overheating problem. Removing it simulates it failing to the open position, which is the coolest way to run any car. If the car runs cool again without the thermostat in place, it is your problem.
croco (04-18-2020)
slburns538
51
08-16-2019 10:49 PM
