F Type passengers window not dropping with handle
Hi all,
I have a 2013 f-type and here is the problem:
From outside I go to the car and unlock it with the fob but when you pull the passenger’s door handle the window it does not drop to pass the seal.
It’s had both the batteries replaced and tried the window re-set procedure.
I have noticed the following:
when you unlock the door from outside the (locked) led is lit up on the passenger’s internal lock button.
so from inside I pressed the unlock button and you can hear it unlock but the orange led stays lit on the locked button.
Driver’s side is fine as the led turns off when unlocked.
Sometimes if I play about with the lock, unlock buttons the led will go off and the door/window drop works every single time until I’ve locked the car up again and same problem occurs.
also if I press unlock from outside wait a few seconds then press unlock again the led goes off and I can get in again no problem until I’ve locked the car up.
Any suggestions please?
Hunnenkoenig
06-03-2022 02:05 PM
