F type power steering motor rebuild
Has anyone out there either rebuilt themselves or had someone rebuild the motor that is attached to the power steering rack on the F type? I'm trying to avoid having to replace the entire rack to the tune of $5k.
I've tried searching other posts but haven't been able to find anything.
The entire rack and pinion setup and motor are all one piece, and the dealer wants $5,200 for a new one. I suppose I could look for an entire piece ( they have them on ebay), but I thought since the motor is the problem, perhaps it could be rebuilt.
In fact I don’t think the problem is in the mechanical part of the motor, the issue is wirh the electronics - wiring and connections are corroded and failing. So its not really a rebuild, i was just wondering what I might be getting myself into in taking this on.
sov211 (01-08-2024)
I was getting water in the trunk during particularly heavy rain and think I've resolved that now. I've got a coupe, and there are plastic channels at the sides of the hatch that feed water to the drains at the rear. There are pins on the underside of these channels that snap into holes in the bodywork. These pins have seals around them and they were not quite sealing. I put a small amount of strip-caulk (also called dum-dum) around those pins and think it's OK now. The rubber on those channels has definitely degraded. It's the same as the plastic to rubber on the piece at the base of the windscreen. It is not holding up.
JgaXkr (01-08-2024)
dpe007
E type ( XK-E )
08-21-2017 04:47 PM
