F Type problems 3.0 V6
If you mean that you are interested in a supercharged V6 F-Type, the answer is that these are very reliable engines. Timing chains do not seem to be an issue on the V6; but other possible issues: leaking at the differential seals, and the timing chain cover seal (this, in turn, can cause alternator damage) - both of these should be checked. Other than these, there can be oxygen sensor failure or fuel injector failure (these are by no means limited to Jaguars). The supercharger coupling can cause rattling noise on start up and shut down.
The major issue with the F-Types is that they are addictive! Simply intoxicating - the performance and handling (and the 6 cylinder is generally thought to be the best balanced), the sound, everything - and they are stunningly beautiful, especially the coupe.
These cars, like all modern luxury cars, like to have full battery voltage all the time so if this is not to be a car in very regular use, fitting a battery minder is a very good idea.
there is a reason why owners of these cars are so enthusiastic...no, let me rephrase: there are many reasons why the owners are so enthusiastic.
Chris: I cannot answer that question because my F-Type (at 52,000 kms) has no extraneous noise from the supercharger coupler, but in addition I suspect that the cost of replacing the coupler might be quite different in Canada than it would be in South Africa.
Perhaps someone who has experienced this issue will comment. As far as I understand, the rattling noise as the engine is started and shut down is simply that: a noise - without further implications (but I stand to be corrected).
Again, the V6 engine does not seem to have chain issues. The F-Type does not have "electrical issues" unless the battery voltage is allowed to drop by lack of use, short runs, or battery defect...and as stated. "Electrical issues" are easily avoided by fitting a battery maintainer.
and in terms of the comparison between an F-Type and an R8...only one of these is both exciting to drive and beautiful, and it isn't the R8 🙂
Carbuff2 (02-13-2021)
Should give you some idea of what it SHOULD cost. If you do it yourself...It is less than $100!
DC
The Book/Labor time listed to perform the Isolator/Coupler is 6.2 Hours(@ whatever labor rate the shop charges). If we assume Dealer @$175/Hr., which is likely toward the top end, it would be ~$1085 Labor plus the part. The part (there are spring type, and solid) is usually under $100.00.
DC
DC
magpies
06-27-2019 08:46 AM
pablomonk
09-28-2018 08:55 AM
