F Type R Catch Can
The following 2 users liked this post by datriani:
rrstl3 (06-22-2022),
Valerie Stabenow (06-23-2022)
The F Type, and all direct injection engines, inject fuel into the cylinders. In previous carbureted, throttle body and port injection engines, the fuel passes through the intake system and acts as a solvent to wash away carbon deposits from the PCV. Since no fuel passes through the intake in direct injection, the “stuff” vented through the PCV can accumulate and restrict flow through the intake.
The F Type, and all direct injection engines, inject fuel into the cylinders. In previous carbureted, throttle body and port injection engines, the fuel passes through the intake system and acts as a solvent to wash away carbon deposits from the PCV valves. Since no fuel passes through the intake in direct injection, the “stuff” vented through the PCV can accumulate and restrict flow through the intake.
Water/Methanol Injection will also (and actually much more so) keep the top end and Valves very clean. They basically get bathed with alcohol steam/mist when the nozzles are spraying. Next time I take the engine apart, I plan on checking to see how well my WMI system is doing to keep it all clean.
Just FYI.
DC
Just FYI.
DC
Good luck,
DC
Received 3,226 Likes
My DIY List Link is HERE - Post#41. Only caveat, is that it is tight in the engine bay (but I have addressed that)…And just make sure the hose is strong or it heat up and collapse on you (not good).
Good luck,
DC
Good luck,
DC
Let us know how you get on as I have been tossing up about doing this for ages now.
I think I'm Ok with most of it, buy good heater hose, is that 1/2 inch ID or OD? Not sure exactly where the holes were drilled.. would that be plastic or metal? It looks like a carpeted area??
Would the purpose of this be similar or replacement to squirting some sort of cleaner in a hose that I saw posted somewhere??
Thank you for your patience, my skillset is mainly water pumps, adjusting rocker arms, fuel pumps, brake boosters etc. on late 60s/early 70s british cars.
EfficientLifeChurch
02-10-2022 11:23 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
