F-type R dyno before intake installation
Burt Gummer (09-15-2017)
sgvkirbster (09-15-2017)
On my prior cars intakes have only added from 5HP to 8HP but none of those were supercharged so, personally, I am interested in learning if there is much difference on these SC'd engines. Looking forward to this so please share once you finish the runs regardless of the results.
So..... I arrived at KT Motoring at approximately 10:15. The car was off for 20-25 minutes before going on the dyno dynamics. 1st pull yielded 414.4 WHP. 2nd pull was lower at 408.2. 3rd pull was 416.2, matching the best run from 10 days ago. After the 3rd pull, the car was turned off and allowed to cool for several minutes. On the 4th pull, she was put in sport mode only (no dynamic, active exhaust off). 423.3 WHP was achieved.
I drew the following conclusions....
1. Eventuri padded their horsepower claims. 7.1 WHP increase is equivalent to about 9 BHP.
(9 x 0.8 = 7.2) This is nowhere near the 30-38 BHP claim they so boldly stated.
2. I could be wrong, but it seems the car achieves higher numbers when it's ran in
normal/sport rather than dynamic/sport. My final run 10 days ago also yielded the
highest numbers (normal + sport). Maybe the car puts power down better when the
suspension is not as stiff?
The owner/dyno operator commented that the car needs a tune to maximize the added power of the CAI. He said the ecu appears to be confused as to what to do with the extra air.
I'll definitely be getting a tune in the near future. My next planned mods are: 1. Quicksilver exhaust. 2. Velocity AP 200-cell cat + downpipe. 3. Velocity AP tune + pulley.
#28
Not to rain on your parade with this; but i think we can effectively say the Eventuri intake does basically nothing. While there was a small bump in horsepower/torque for roughly 250 rpm, the rest of the curve is completely unchanged. For this to be an effective modification, you'd need that horsepower/torque increase to be across the entire (or a good portion of the) usable RPM band.
A lot of manufactures play this game, which is why we demand dyno charts to make our own conclusions. Its great if you hear them say their intake, exhaust, heads, whatever; makes XX.X horsepower, but that's only your peak gain and never even comes close to the average gain across the usable RPM band. And that's the information you really need if you're going to make smart performance decisions.
#30
Indeed, a tune could be mandatory with this mod. I personally believe most mods don't work without tuning.
#31
My comment is not directed at the car owner, rather the comment from the dyno owner/ operator about "the ecu appearing to be confused about extra air"
I realise it may be down to poor choice of words but it implies serious lack of knowledge.
Humans can be confused, micro processors in ecu can't.
The program will take data from all sensors such as MAF , MAP etc it measures airflow , air temp, rpm, derives air density then uses this information to look up ignition timing and fuel required. Most turbo and supercharged engines will go with richer mixture when things get hot.
Most std ecu maps will accomodate a certain increase in airflow and select the appropriate fuelling without problems or needing a "remap".
Only substantial airflow increases are likely to to exceed the values in the airflow table and / or the capability of the fuel injectors to provide the appropriate fuelling to maintain lambda necessary to make effective use of the extra airflow.
jrodrg (01-31-2018)
#32
+1
Remember also that the ECU has torque limiters active, so it will control the throttle to stay at the factory determined torque levels.
So if you increase airflow, being it with a pulley or a better intake, the ECU will still cap the power to factory levels (give or take). The ECU is using he MAF and MAP signals for it.
So the only way to know how much the intake would add, is to have the limiters removed from the ECU, then do a before dyno and only the than install the intake and do a after one.
Ideally you would 1st check the actual vacuum of the intake, as that will determine if there is room for improvement.
#33
I know that like all dyno posts this has the potential for controversy.
#34
+1
#35
Which is why the Velocity AP tune is on my bucket list. In fact, I'm been thinking about skipping the quicksilver exhaust altogether and just jumping straight to the tune, pulley, and 200 cats. I have just over 7.7k miles on the car at the moment. I was planning on doing a 2nd oil change (my 1st was a little over 1k miles) before doing the tune. But I'm feeling a little impulsive at the moment, like I wanna just jump right into it. What do u guys think? Should I just wait for the oil change or pull the trigger now?
sgvkirbster (09-16-2017)
#36
#37
Yes.
#38
Sorry if I missed you yesterday. I was on a court ordered work furlough.....
![Icon Laugh](https://www.jaguarforums.com/forum/images/smilies/icon_laugh.gif)
Actually, I was out in the woods chasing grouse and getting my cardio in. I work so much I need to get out and clear my head sometimes.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#40
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
