F-Type R intake/tube issue?
Hello all,
I’m looking for some help and guidance. I installed a Mina Gallery upper intake tube, Mina Galley’s lower intake, and VAP Tune. When I’m cruising on the highway (75ish mph) and stomp on the gas, it downshifts and when it hits 6k’ish RPMs it starts to bounce like it’s hitting the rev limiter and won’t shift unless I come off the gas or shift manually. When I put the stock file back on the problem goes away. Chris from VAP has been great and is extremely helpful, he is sending me numerous updated tunes until the issue goes away. Has anyone else experienced this? What are your thoughts/opinions? And do you think it could be more so a tube issue or intake issue or both?
At this time I’m unable to upload the video clips.
Last edited by F-Type R 16; 07-28-2020 at 07:37 PM. Reason: Attachment not adding on
F-Type R 16 (07-29-2020)
Hello all,
Also, these intakes "MAY" create a slightly higher air flow (maybe)...but mainly just increase sound, so I cannot imagine with or without a tune, that the intakes would do anything, unless they are not seated properly and you are somehow getting unmetered air into your system.
So leaks would be the only thing the intakes could possibly add to the issue in my opinion.
Good luck.
DC
Hard to tell from this clip, but from what I can see/hear, it looks/sounds like the rev limiter was lowered with the tune. Again, hard to discern, but sounds like bouncing off the rev limiter, but it is not to redline yet....rev limiter lowered (they can be changed with tunes).
You could probably hear better than I can on the video...just my thought.
DC
DC
DC
DC
Good luck with it!
DC
Could it be that the tables are not setup for the free flow of the Mina intake, i.e it's setup for the OEM intake.
I know it's a long shot and doubt if it's really quantifiable, but seems like the only odd variable out.
So many people have the VAP tune and OEM intakes without any issues...
Chris was saying that too but I informed him of all the mods and he said it shouldn’t be a problem but it may be worth trying to put the OEM intakes back on. I just can’t swap them out at the moment due to have my garage floor redone. But again, lots of people have intakes with the VAP and no issues too. It’s just a weird case in my opinion.
Another few weeks we’ll see if we have the same problem on the V6.
That’s a good thought but under WOT the MAF doesn’t come into play, right? Wouldn’t it cause drive-ability issues throughout the RPMs and possibly throw a code? I’m stumped haha when I’m able to I’m going to put the stock intake on just to make sure.
What's on the horizon in to weeks? My upper Mina intake should arrive tomorrow, woo hoo!
F-Type R 16 (08-10-2020)
Received 3,226 Likes
Every time I check their site, including 20 seconds ago, there is no trace of it!
crickets, I think that means if Unhinged told you he would have to send someone down under to snuff you out.
International callers: 1-818-342-0273
You can also email them @ info@minagallery.com
DC
