F-Type R Spark Plug / Coil Change DIY
Hi Group...
As I mentioned in my previous threads and have done on other items, I took some photos and documented the Spark Plug Change Process I just completed, and put them in my DIY format. I have attached the process here.
As always, these are created in the spirit of helping others. If you have a better way of doing it, knock yourself out...this is simply what worked for me. Hope this is helpful for those considering doing it.
It is NOT a piece of cake but is not that difficult, and most can do it with patience and making some tools, as I did
I have tested the car afterwards and it runs great! So ....Why am I changing my plugs with such low miles?? I put a Lower Crank Pulley and I am getting a VAP Stage II Tune, and wanted to use the NGK Iridiums that are 1 range cooler and gapped down to .036 to accommodate and optimize that set up.
Take care
DC
Take care
DC
The following 10 users liked this post by Therock88:
Carbuff2 (09-19-2020),
ferrral (09-19-2020),
jorge429 (12-18-2020),
karamayoko (10-28-2022),
madmax1911 (09-20-2020),
and 5 others liked this post.
Good write up. This tool set makes it much easier to remove and replace coil fixing bolts.
https://www.nationaltoolwarehouse.co...SABEgJHsvD_BwE
Nice write-up, I wish I had this a week ago!
I ended up using many of the same tools, although that magnetic extension you have looks nifty. I simply used needle nose pliers to finish opening two of the driver's side coil screws that were closest to the body.
Any tips on putting the rubber cover back on the driver's side? It's ridiculously tight there and I was hesitant to force it to avoid breaking any of the plastic bits. I suspect there must be a proper technique for sliding it below the ignition coils.
Thanks for sharing.
DC
Best of luck!
DC
MM
The following 2 users liked this post by sparayno1:
gride (02-18-2022),
HermanWiegman (11-21-2023)
watson6505
11-28-2019 12:03 PM
