F-type R stock boost curve
Hi All,
I was wondering if any of you F-type R enthusiasts have logged the boost while running your stock file or tune on the stock pulley. I'm only managing to reach 9.0-9.5 psi max by reading the PID output from the MAP sensor and correcting for atm pressure. Seems low. Data is appreciated! Thanks.
Hi All,
Smoke Em (05-01-2016)
The 3.0L supercharger is different, same style TVS, but a smaller displacement. (smaller casing, smaller rotors)
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
No worries, I'm 100% on this...there both sitting on the shelf in front of me! :-)
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
Methanol boost pressure sensor
hey unhingd. I have a methanol kit. Going with 4 port injection through the plenum. However, i an not sure where i should connect my kit’s boost sensor for injection reference. Do you think there is any other location to fit it other than tapping into the SC plenum?
If you are triggering from a vacuum, most tap the plenum, but really any variable vacuum will work as you are just looking for a relative change (i.e. it does not matter if it is 1 - 5 units or 4 - 10 units...Just a relative trigger of when to start spraying and when to max it out - assuming you are using a variable controller, which I recommend).
Below is where another member tapped in for a reference. You have to remove the cover to drill for your nozzles anyway (you do NOT want to put them in the intake tubes in front of the TB).
DC
Reaxions (09-26-2022)
