F-Type R: tire pressure at delivery?
Love the car, but I noticed some vibration at 70-75, on the highway. Similar to a out of balance tire, but not consistent.
Before taking it in, I checked the cold air pressure. 50+ PSi in each tire.
Per the book and door sticker, it should be 36.
Anyone have a similar issue?
I haven't got back out on the highway yet to see if that cured the problem.
definitely NOT 50+ PSI. they probably inflated it incorrectly because they have a 50 psi stamped on the tire sidewall. But that's unrelated to what you should have your tires pressure set to.
36 PSI is the manufacturer recommendation.
If you drive your car very aggressively (hard braking, cornering, etc.) you'll get more performance if you actually lower the pressure to something around 31psi cold (since it'll heat up more from the aggressive driving). That's per Jaguar track day recommendations.
So yes, let some air out to get it back down to 36psi cold.
My F bounced all over the place when I picked it up until I quickly realized that the tire pressure was ridiculously high. I was surprised that the dealer never adjusted them during pre-delivery. I recently took delivery on a 2015 Grand Cherokee and had the same issue. I assume they over inflate them during production to test the seal... Just the same you would think that the dealers know this and would adjust them accordingly.
Aus V8S
11-13-2015 11:01 AM
