F-Type R's Brakes May Temporarily Lock Up if the Car Sits for Extended Periods
Taking advantage of a few brief moments of sun last week, I gave my "R" a good heat cycle after it sat in the garage since late Fall. When I attempted to back out, the car stayed put. Brakes locked. I tried again, this time with more throttle. The Jag lifted up like it was in full power-brake mode on some starting line; but, still a big no-go on moving backwards. After a couple more rockin' tries, a prayer, and even more throttle, the pads finally broke loose with a shuttering, intestinal-ripping "clunk-clunk." Drove around for an hour. Brakes worked fine. Figured the pads didn't desert their rotor buds (this time anyway).
My thoughts. Just before "storing" the Jag, I washed it and drove around the block to dry the brakes; Apparently, not enough. I have just under 4K miles and figure the pads are still rather close to the rotors. (They likely have a high metallic content as well.) So, the next time I plan to let the Jag sit for any appreciable time (not just a day or three) AND wash it, I'll drive a few miles to help ensure the brakes are sufficiently dry to prevent the situation from reoccurring. And, I'll let the car idle for 15-20 secs without pressing the brake pedal just after I come to a stop in my garage and before shutting off the ignition to assist the pads in moving away from the rotors. (Don't know if this last step is a must-do for the F-Type, and I've never owned a Jag before. But, this brake pedal technique is recommended by some manufs (it's in the GT-R Owner's Manual for one.)
If this was covered previously, sorry.
I think it's quite possible your park brake didn't disengage. I leave mine off and just engage Park if I'm leaving my car anywhere for an extended period (in winter).
Unhingd (01-25-2015)
This is not unique to the F-Type, it also happens with my XJR (loud bang as the brakes release and you get moving) it's the park brake pads sticking to the rotors if you park it up wet or if you have washed the car.
If you can, don't engage the park brake when you park up the car if the brakes are wet or you have used wheel cleaner. I find the wheel cleaner leaves some sort of residue on the brake rotors.
I would never park up a car for extended periods with the park brake on.
Received 2,263 Likes
I've never experienced anything similar, but I don't let my cars sit idle that long. I didn't read anything about the parking brake in the OP's account, but I agree with the parking brake explanation if it was engaged. There's no reason to use it on flat ground, as hopefully exists in one's garage. It's also a really good idea to dry the rotors and pads after a thorough wheel cleaning.
I know the stall was due to pad-rotor lock because the parking brake was off (only works on the rear I believe), and because of several previous locking experiences in my GT-R. Since I was already aware of this possibility after washing, I drove the car "around the block" (about a 3/4 mi) before garaging it. But obviously, I still need a little more driving/drying time as I said earlier.
Thanks to all of you for your insights. Much appreciated. (And props to you both, Cambo351 and Mikey--tons of posts to check, but you're right there.)
BrentGardner
28
04-26-2024 03:08 AM
msdg137
09-16-2015 06:24 AM
Terrance Williams
08-26-2015 11:50 AM
