F-type specific 20" tire size opinions/insights request
Old 04-23-2022, 02:13 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
The tire compound and construction will make a far greater difference in ride and handling than the 10mm increase in tire width. Get rid of the Pirellis.
Old 05-02-2022, 11:20 AM
ViperX100's Avatar
@powerhouse Thanks for the write-up. What brand spacers did you go with?
Old 05-03-2022, 03:21 AM
powerhouse's Avatar
H&R spacers and Eibach springs
ViperX100 (05-03-2022)
Old 03-02-2024, 06:25 AM
thewolfman800's Avatar
Question
Originally Posted by Mark7Seven
Are spacers to make the OEM tires appear wider even on the radar for you? I’ve seen at least one owner who installed them and liked the outcome.
https://youtu.be/qwIWhD7lPkE
I have the same F-type and I love your wheels. Looking to change out and I was wondering if you could share the manufacturer's name of them. Thanks
Old 03-05-2024, 01:35 PM
WhiteTardis's Avatar
Another dirty secret about the tire industry is that tire measurements are not standardized across the industry!
For example:
Michelin PS 4S 295/30/20 has an actual measured width of 11.1" or 281mm
Michelin PS 4S 305/30/20 has an actual measured width of 11.2" or 284mm
Pirelli PZero 295/30/20 has an actual measured width of 10.1" or 256mm
Pirelli PZero 305/30/20 has an actual measured width of 10.8" or 274mm
Another consideration is that even though a specific tire size can be mounted on an approved rim, that does not mean better handling:
Using a Pirelli 305 (274MM) tire as a an example, it is rated to be mounted on a rim from 10.5-11.5 inches
- If mounted on a narrower rim (10.5" or 266mm), you'll have 8mm of shoulder roll when you corner (274mm-266mm)
- If mounted on a wider rim (11" or 280mm) you'll have 6 mm of shoulder roll when you corner (280mm-274mm)
I'd watch the video below:
https://www.tirerack.com/videos/inde...=946&tab=Tires
DJS (03-05-2024)
alibaba
07-23-2021 10:06 AM
slojotaa
10-16-2019 10:22 AM
StuG
Australia - Queensland
11-27-2015 04:39 AM
Cambo
12-20-2013 02:23 PM
Quick Reply: F-type specific 20" tire size opinions/insights request
