F Type Sport 400 discussion thread
Might be far more cost effective to retrofit those seats into your existing car (with the benefit of keeping the MT). I'd bet the mounting locations for the rails are identical.
SinF (01-11-2017)
If the new one is 400hp tired that means the tunes out for these only bump it up by 19hp?
I see the VAP tune is 419hp on any model V6 so they are only tuning in about 19hp increase? Maybe VAP will get a hold of this tune to see what the differences are and then revisit their tune for another bump in power maybe/hopefully?
JLR could get themselves in trouble for advertising 380hp and delivering less than that (which I have confirmed with the baseline dyno @ 367).Jaguar F-TYPE - Coupe & Convertible Models | Jaguar USA
Dave
Your logic is correct, but the actual rwhp came in at 313. I had to make an assumption (though, a generally accepted one) that the powertrain loss is around 15%. That assumption could be off by a % or two, potentially putting the advertised number right on the actual mark. Thanks for bringing up that point.
DPelletier (01-11-2017)
#28
#30
I guess it depends on if they only bumped up the peak hp or if the new tune has more torque/power across the the whole rev range.
Dunno if you saw the dyno charts from unhingd's tune, but it was a big fat gain in the mid range, on top of higher peak numbers.
20hp on top of 375hp, yes I think you might notice it. When the WOT flap on the intake of my XJR failed shut and I lost 15rwhp (proven on a dyno) I certainly noticed it... The XJR is making more or less the same power as as these V6S...
None of these early press releases have given away any torque numbers, and no back-to-back test drives of a V6S vs a 400 yet, so it's hard to say for sure...
#31
+1. If they did bump the torque by more than 25 lb-ft , that could be the reason it will not be offered with the MT. Too close to the nominal maximum torque specified for the ZF S6-45.
#34
+1. Put the word Sport and a nice big round number like 400 on the car and it will be perceived as a HUGE upgrade / revision from the S. In reality its just a few more BHP and some badges.
#35
Wait...367 hp at the wheels? Or the crank?
Cause at the wheels 367 hp could mean as much as 410+ hp at the crank, depending on your driven wheels (RWD/AWD) and the transmission. No?
#36
#37
#38
bumping a semi-old thread here but...
Those of you with the 380PS F-type may shrug at +20PS, but for us XE owners with the 340PS engine, a 60PS gain would be very noticeable (slightly under 20% gain!). The prospect of flashing a factory-approved 400PS tune to the XE is pretty exciting.
are we sure the only power upgrade will be in the ECU?
Would we put it past JLR to have utilized either a smaller crank pulley or perhaps upgraded cooling? (if the intercooler is shared in V6/V8 engines, the latter would be pointless of course).
#39
#40
