F-Type Stereo System Upgrade Planning
#81
Jeremy, I finally got a chance to watch your 2nd video.
Your car has the NGI Infotainment system in it, this is the newer version that uses Ethernet for data transmission between the head unit and the amp, not MOST fibre optic like the earlier cars.
The Mobridge DA-1 is not going to work with this system.
Here in this screenshot;
![F-Type Stereo System Upgrade Planning-screen-shot-03-14-18-11.38-am.jpg](https://www.jaguarforums.com/forum/attachments/f-type-x152-72/211496d1520987947t-f-type-stereo-system-upgrade-planning-screen-shot-03-14-18-11.38-am.jpg)
Your hand is on the IMC "Infotainment Master Controller" from the NGI system, not the Sirius receiver
The amp above your hand is an NGI amp.
"At first glance I don't see the fibre optic cable that I need" yes because it's not there, there is no fibre optics in this car, it's Ethernet.
Sorry to be a bearer of bad news, but I guess you already figured that out.
#83
DJS (03-22-2018)
#84
Not much of an upgrade over the premium meridian stock system?
#85
If you mean the 770W Meridian Surround, then we have not tried these exact speakers in one of those yet.
And the 380W system in this 2017 is not the same from an electronics & software point of view as the 2014-2015 cars with 380W, or the 770W Meridian up to 2017 either.
But slojotaa upgraded his 770W system with some other OEM Kevlar speakers (yellow "B&W" Kevlar) and reported a considerable improvement.
At the end of the day, the factory speakers in both the 380W and the 770W Meridian are not the best JLR have to offer, there is definitely room for improvement, whichever way you go.
slojotaa (03-30-2018)
#86
#87
Thank you for that information Cambo. I plan to remove the speakers to dynamat behind them. Without adding an aftermarket processor or amplifier, do you feel there is an advantage to be gained in sound quality swapping out my 770w meridian speakers (from 2014!) to an aftermarket replacement? I've had great success in my other cars just upgrading the speakers alone for an improvement in sound quality (albeit may be a result of years of usage as well,) or installing new OEM speakers.
My own choice would be the Meridian Signature ones like I posted in the pics above, for three reasons;
#1 they are used in the highest spec audio systems from Jaguar Land Rover, so there is something better about them, than what was installed originally.
#2 they literally bolt in & out, much easier to install, no cutting wires, no drilling, no modification, straight swap. The impedence is the same as the originals too.
#3 they are still cheaper than the aftermarket speakers that are designed to fit into that odd 200mm hole, from Eton, Focal, etc...
You can fit any speaker you like if you make/modify the mounting & wiring, but this takes time/effort/money and may not be easily reversible (if you cut wires).
You ask different people you'll get different opinions, that's just my opinion.
#88
It's just my opinion, but yes, you can improve the sound in the F-Type by changing speakers.
#89
Based on some great info provided by Cambo I looked at price of B&W 2cd2077 vs Meridian Signature 2cd24863. The B&W is about $35 per speaker more than Meridian, but the mid ranges are about same. Also the Meridian midrange is about the same cost as the Meridian bass. Curious for sure as Meridian signature supposed to be better.
#90
I tried to order a set of Meridian Signature online from oem dealers. Specifically c2d30486 (tweeter); c2d24862 (midrange) and c2d24863 (bass). I was told by two different dealers that the bass speaker has to be ordered from JLR in England. One told me they may not get it, even if ordered. Not a confidence builder. The B&W c2d2077 bass speaker is available in USA ($35 more each). Not sure if mix and match is an issue. In order to hit my timeline for other work I need to buy now or put off to another time line or find a local installer as current appointment for xpel is 90 minutes away. I may go mix and match and take my chances; not a scientific studied approach for sure. Audio guys must be cringing. I think the gamble is whether the crossover frequencies already set up in the head unit are compatible with replacement speakers. I would expect they should be similar. Seat of the pants science. Any constructive thoughts welcome. Option B; scrap the idea and focus on new set of wheels.
#91
I tried to order a set of Meridian Signature online from oem dealers. Specifically c2d30486 (tweeter); c2d24863 (midrange) and c2d24863 (bass). I was told by two different dealers that the bass speaker has to be ordered from JLR in England. One told me they may not get it, even if ordered. Not a confidence builder. The B&W c2d2077 bass speaker is available in USA ($35 more each). Not sure if mix and match is an issue. In order to hit my timeline for other work I need to buy now or put off to another time line or find a local installer as current appointment for xpel is 90 minutes away. I may go mix and match and take my chances; not a scientific studied approach for sure. Audio guys must be cringing. I think the gamble is whether the crossover frequencies already set up in the head unit are compatible with replacement speakers. I would expect they should be similar. Seat of the pants science. Any constructive thoughts welcome. Option B; scrap the idea and focus on new set of wheels.
jaguny (03-28-2018)
#92
Their shipping charges from the UK are very reasonable as well.
jaguny (03-28-2018)
#94
Cambo....I am changing out next week one of 2 of the final speaker upgrades. I plan on taking the plunge and changing out the single dash speaker to complete the front sound mod's.
The only thing i have not "yet" done is to change the tweeters (no need to in my opinion, they are fine), and the rear speakers behind the seats. They are useless to me the way they are now. I want to get more power from behind "seats that muffle the sound based upon design anyway), and want your suggestions on:
a) - Have you done this?
b) - What did you replace back there?
c) - Any other inputs on rounding out the finale of the rear seat speakers so that it is as successful as the other changes I made to the car based upon your well placed inputs. Success on that front.
Thanks mate,
joe
Thanks mate,
joe
#95
There is no "factory upgrade" for the rear speakers. See post #77 https://www.jaguarforums.com/forum/f...2/#post1857560
A friend of ours did fit some aftermarket speakers in there though, but you need to cut up the original bits to make them fit.
![F-Type Stereo System Upgrade Planning-luidprekers.jpg](https://www.jaguarforums.com/forum/attachments/f-type-x152-72/212261d1522406047t-f-type-stereo-system-upgrade-planning-luidprekers.jpg)
![F-Type Stereo System Upgrade Planning-inbouw.jpg](https://www.jaguarforums.com/forum/attachments/f-type-x152-72/212262d1522406047t-f-type-stereo-system-upgrade-planning-inbouw.jpg)
That's about all I can tell you...
behind the seats I choose the Ampire Bold 6 as subwoofer (the speaker has a double coil): https://www.ebay.de/itm/Ampire-Bold-...d/122058389231
And for the midrange speaker Audison Voce AV 3.0 because this speaker fits the original frame: https://www.ebay.de/itm/Audison-Voce...r/263026454633
The combination of the Ampire subwoofer and the Audison midrange speaker is interesting because they are much better then the original JLR speakers and less expensive.
Because of the double coil you can connect them easily to the surround amplfier.
I was wondering that the sound quality now is so good as the amplifier has filtered outputs for the original speakers but it sounds very good with this combination of high quality speakers.
#96
Update: so far I decided to purchase the B&W 100mm (c2d2076) and 200m (c2d2077) along with the titanium meridian tweeter. Not all have arrived, but the 100mm is yellow Kevlar. The 200 mm is still a paper cone. I am trying to confirm if the Meridian Signature is Kevlar (black) as it appears to be from Cambo's info. I am calling supplier Monday to see if the Meridian's are in stock and they can check first hand. More to follow as I progress. If I can get it all sorted, installation won't be complete until April 20. The way its been snowing with cold, the Jag may not make it to the appointment.
#97
jaguny (04-07-2018)
#98
Thanks Cambo. I expected so from your posted info. I went with the B&W as having had them in by XF, I had liked them and expected the 200mm would be Kevlar like the 100mm. Also Joe liked his. Curious that the c2d2077 are paper. I may go ahead and get the Meridians. They are actually cheaper; the c2d2076 indicate they are made in Slovakia, at least on the box. Haven't looked at the speaker itself to see if there is a stamp on the speaker. I think you indicated all are now made in China.
Also the supplier mistakenly sent a 2cd2079 coaxial instead of a 2cd2076. Is that a upgrade/fit for anywhere in the f type?
#99
Similar but slightly different. I have ordered the Meridian Signature speakers but the Land Rover Variant :- seemed to be cheaper. LR047119, LR033293 & LR03392. Once the weather clears up Ill get the door cards off and install.I have also got some dynomat to through in at the same time.
Paul
Paul
