F-Type SVR Discussion Thread
#501
Maybe someone with a svr can chime in on this one
on the picture in the configurator i noticed there is a extra button on the steering wheel which is a bit to blurry to make out properly, either way this is not on my current R and only seems to change if its the svr spec?
Almost looks like a speech/voice activation symbol?
Confused!
Confused!
#502
#503
Not yet looked at the USA configurator, i'll have a look later.
But correct me if im wrong but i thought the f-type does not have any form of voice command features?
Also regardless of the options you chose on a f-type R you can not get this button to appear so i doubt it its a market/region thing.
Maybe a mistake?
Maybe a mistake?
#504
Maybe a mistake?
Maybe a mistake?
#505
Maybe a mistake?
Maybe a mistake?
Maybe planned then cut.
#506
I'll have to look at the "just drive" app. Not seen it yet, Cheers.
#507
Here's an interesting one: I know that the engine cover has been removed for the SVR, as with the P7...and I have seen an interview somewhere where some Jag person said they didn't advise putting the cover on and SVR due to the heat (does that extra 25hp really make that much difference?). Anyway, the official Jag accessories catalog actually states that the CF cover is "not applicable to SVR". Huh? As in it won't fit? Bizarre.
#508
#509
#510
Oh that's an interesting thought! Can anyone familiar with the F type engine bay confirm if the SVR has the attachment points from photos? That'd suck. My cars tend to wind up on display a lot, and I'd been counting on being able to fit the CF cover (I'd remove it at the track and for daily driving, I'm aware of the heat issues).
Another thought: it seems the underside of the bonnet has some extra rubber/plastic lining around the vents and so on on the SVR. I wonder if that makes it too tight a fit?
#511
Perhaps so, but they are just 4 identical pegs with a ball on top and threads on the bottom that screw into housings and brackets that are common to all the models. A picture of the SVR engine bay should clear it up. Anyone?
#512
#513
#514
Received 3,225 Likes
Confused!
Confused!
#516
#520
