F-Type SVR Discussion Thread
#681
#682
#683
first thing i did was replace all the red badges, they just didn't work on my colour combo
i've been meaning to remove the R badge up front too, but looks like i need to get behind the grille and cbb removing bumper for it - working up courage to carefully dremel it off
Got my black front growler badge, but how do I removed the original red growler badge please?
#684
If someone has a better suggestion I'm all ears!
#685
Received 3,258 Likes
The badge is simply glued on with what appears to be the same glue that they use for chrome/plastic lettering etc - grey coloured and very sticky but not impossible to budge.
On the XFS I poked a very small screwdriver into the tiny gap around the outside of the badge, then gently levered away. If I had my time over again I would probably use a very thin plastic trim removal tool instead. Then, once you get one side/edge of the badge to lift a little stick a bigger lever in there (again I would use a trim removal tool) and keep gently levering while working around the badge. Eventually it will come all the way off.
Clean up the glue residue (but no need to go nuts, a little left behind is no problem) and the new badge should simply be a case of "peel and stick".
The new badge should have two locating tangs/prongs on the back of it that go into two holes/slots on the mounting plate so you can't go wrong positioning it.
FeralSVR (03-09-2018)
#687
#688
[QUOTE=OpusX;1856116]The standard F-Type STO N SHO DOES fit our SVR's. I have had it installed for 6 months now without any issues. Simple install and no modifications made to the bracket.
Thanks OpusX!
Is it model #SNS139? Do the two mounting bars fit above the chin piece and below the carbon fiber splitter? It sounds like it mounts directly to the hole in the middle like all other F-Types(?). I was concerned that the C/F splitter stuck out too far and the bracket arms weren't long enough.
Thanks OpusX!
#690
#692
#693
#696
Here is round two where his launch is better though still cannot match the SVR, but he stays flat and passes me around 150mph.
#697
AWD / SVR owners after speaking with Dale Lomas today I've had it confirmed I was not imagining it about the car feeling more sure footed in the wet when in wet mode instead of dynamic. He has confirmed the car in wet mode puts the AWD split as close to 50/50 as possible, whereas dynamic mode is 90% rear driven. He said at the ring he uses wet mode when the track is wet or slippery with traction fully off and manual sport gears as it gives a real advantage over leaving the car in dynamic mode. So its confirmed on AWD cars the modes do impact the AWD torque split.
FeralSVR (03-13-2018)
#698
#699
All the modes change is the throttle curve effectively making the pedal longest in rain mode, longer in normal and shortest in dynamic amongst other areas of the car such as dampers, traction control, gearbox, steering and the AWD split.
10% throttle in dynamic gives you 20% power.
10% throttle in normal gives you 10% power.
10% throttle in rain gives you 5% power.
100% throttle gives you full power in all modes.
They just change the throttle mapping to make the pedal more or less sensitive.
I did several 1 mile runs last weekend and in wet mode I hit 186mph, in dynamic mode I also hit 186mph.
#700
Interesting, Would love to see the differences in launch times (0 to 60mph runs) between the modes. I am assuming you are including manual shifting, because in rain snow mode, it shifts way too quick (even in sports transmission mode). It surely does not let the revs fly from my experience. Or may be I need to floor it. Another 1000 miles to complete my break in.
