F-Type SVR Production numbers and more
#161
2017MY 914 - I'm most likely missing some pre-prod ones.
2018MY 384 - Used to be 380 but I recently found 4 more SVRs while I was finishing up finding the manual ones.
2019MY 331
2020MY 250
Thank you for being able to gather this info. This confirms my findings and the numbers of SVRs at around 1868-1883.
#162
Ftyperegistry (04-30-2021)
#163
#164
#165
Which ones is yours?
SAJAL6847HMK40769 <- - I am assuming this one since you added it has the carbon roof.
SAJAL6845HMK40785
SAJAL6842HMK44227
#166
2017 115 - 25%
2018 21 - 40% - only 18 in the US remain since the 3 Pre-Prod ones with CCB have not been seen publicly since late 2018. Probably destroyed or kept by Jaguar somewhere.
2019 27 - 38%
2020 30 - 33%
Portlander (05-03-2021)
#167
You are legend ..thanks for the stats/...
mine is this one SAJAL6842HMK44227 with panoramic glass roof, ceramic brakes and carbon pack. cheers.
so id say the SVR should increase in value in about 10 years ?
#168
Here's a couple pics of ur SVR. There's also a couple more I seen in Instagram at
#169
Ftyperegistry (05-20-2021)
#171
Here's an interesting SVR that popped up for sale last month. I had this marked as Caldera Red when I got the data from Topix but Description on the listing says it is Firenze Red (Topix data is innacurate for almost all SVO/Bespoke colors). The Info section of the ad says it is Caldera Red. Unfortunately the paint code on the VIN door jamb sticker has been covered with marker for some reason. However it does says Bespoke on the sticker. So not sure what to believe. The color does seem to be darker than Caldera Red. If it is in fact Firenze Red it will make it the only SVR in that color. https://www.jaguardowntownsaltlake.c...z1fe0jck54213/
#172
DJS (05-21-2021)
#174
JacksonvilleJag (05-22-2021)
#175
#177
#178
Thanks FeralSVR for confirming. I was going to reach out to you since you are the only forum member I know that has an SVO Bespoke color before 2019 when they officially added SVO colors as an option.
#180
Indeed I did in the end! What a beautiful car! The sound is out of this world! Strangely enough also saw another of the very few SVRs yesterday. But then again I live fairly close to the JLR plant in Solihull!
