F-type Updated head unit (Android + apple car play + android auto)
Old 06-03-2024, 06:28 PM
Borbor's Avatar
Do you have a link for the original listing where you bought the unit?
The size discrepancy suggest that is not even the correct unit for the f-type.
Also you are not going to damage the Oem system by just unplugging. Make sure everting is pushed/connected in gently but firmly and locked in. It is possible to bend pins in the connector if you are rough so check these as well
Old 06-03-2024, 06:51 PM
Ray Ray's Avatar
I don’t remember a whole lot of details but the supplied back plate/cover was very similar to the og style and fittment was perfect.
My unit is also different in that a new screen with bezel was included, can’t tell if your has that.
The pic also looks like it was made for a Range Rover model, but I’m not entirely sure, just a faint image of it when i did the research.
And even if it was made for a Range Rover, it should technically still power up at least when power is supplied, i believe the power is supplied by the og screen internals, nothing special about it, plug until you hear a click.
Old 06-03-2024, 07:14 PM
mattison's Avatar
I'll check all the pin connections for any bends, but all connectors slid in very easily and did "click" into place. The box I recieved was labled "F TYPE 13 - 19 and the screen did have the surround attached
From Carputech
Old 06-04-2024, 06:08 PM
mattison's Avatar
Happy Day! I was able to get my original screen working again. I have no idea what happened, but I disassembled everything to inspect and then reassembled. While my unit was apart , I tried one more time to fit the new screen because I what I was told was " I assure you it will fit". Nope. Just waiting on return info now. (fingers crossed)
Old 06-04-2024, 08:03 PM
Turko's Avatar
Default Another provider of Android Auto
I saw this and I thought it might be helpful as a different product which might be better?
https://www.niftycity.shop/collectio...ch&seed=307247
Old 06-17-2024, 07:23 PM
Jag EP's Avatar
Hello everyone. Im new to this forum. I recently install an Android unit in to my F type convertible.
Hope this helps to answer some of the questions...
Ray Ray
07-28-2023 09:39 PM
owexonline
XE ( X760 )
79
06-03-2023 09:25 AM
Amphicar770
12-21-2022 07:58 AM
Alboy
11-10-2022 06:56 AM
Jag4
09-12-2022 07:49 AM
Quick Reply: F-type Updated head unit (Android + apple car play + android auto)
