F Type V6 S Convertible - Highway Drone
Recently picked up a 2014 V6 S and love the car. But when cruising on the highway in 8th gear at 75 MPH, where the RPMs are right around 2k, I get constant exhaust noise or drone everytime I lightly touch the throttle. This happens in Dynamic, Normal, or Snow mode. I checked to see if maybe the previous owner pulled fuse F43 to keep the active exhaust flap open all the time, but that was still in place.
Can other convertible owners chime in and let me know if this is by design? Or is my active exhaust not closing the valve/flap at lower RPMs?
I only get that once I've pulled F43, which powers down the active exhaust vacuum pump. I'd guess the valve, vacuum solenoid, or valves has failed.
Vacuum pump and solenoid are located behind the left rear wheel. My pump buzzes a lot around 1400RPM, and as my valves are squeaky, I can hear them open and close.
Yes, verified that it is the stock exhaust.
I am assuming something has failed, I don't hear any valves closing after it goes through the initial start up cycle. The exhaust is constantly loud. I am assuming no codes thrown is normal behavior if some mechanism fails within the AE setup.
I have a 2014 V8S and there was a problem fixed under warranty where the lubricant on the active exhaust baked off and they made a horrid squeaking noise when they operated. I expect, if not corrected, they'd eventually stick. This resulted in replacing the system and it hasn't had the problem since. But I'll bet the valves have stuck.
Even with the switch off, I don’t think there’s enough vacuum to close the valves at idle. Mine won’t close until the engine RPM is up just a bit. Maybe that’s just at start.
On start mine's initially loud, but vacuum builds quickly enough that it'll quiet down. Once it comes off of fast idle, three's a noticeable difference between off and on. When that stopped, it was a sign that something was amiss. The vacuum leak was at the firewall right behind the symposer. Fortunately it was easy to find and patch. Not sure how they found it. Maybe smoke?
Ya same with mine, on cold start its loud, then if the exhaust is off it quiets down but while the revs are still up if I turn it on it will make a noticeable difference, once the car is up to Temp I can here no difference during idle, when its off the valves dont close till 1500-1750 RPM then I can here them close, but then will open again after 4 or 5k rpm. Lately they have been rattling and squeaking, I am already on my third exhaust on the F-type, all replaced by warranty.
enderle (06-20-2019)
I would get the VAP exhaust 100% if it wasn't for the warranty issue, I know generally a catback or axleback would not void any warranty, but Since My cat's have been replaced twice already, I don't want to void the exhaust warranty either, Plus I'm still not sure if the car is going to be bought back by the dealer, Lawyers are going at it. Jaguar NA did offer me a few thousand in compensation for the issues I had with the car, but still fighting for the dealer buyback. Next car- Either R coupe or RS5
emmsys
09-28-2009 03:53 PM
