F-type V6 S LSD oil
According to my copy of the Workshop Manual it is JLR part # BOT720 (which is a Castrol fluid but apparently you can only get it from JLR dealers) and the quantities are .84 - .86 litres dry fill and .815 - .835 litres wet fill. The V6S LSD uses the same diff oil as the V8R e-diff, but the base V6 with the open diff uses a different oil.
With a quick search I couldn't find an alternative for the BOT720, and being an LSD I wouldn't risk anything else.
Update - after some more research it seems there is an alternative to the Castrol BOT720, and it may in fact be the exact same stuff - Ravenol MDL, see here: https://www.ebay.com/itm/RAVENOL-MDL...841?rmvSB=true
SinF (02-28-2018)
Jagged Wire (02-28-2018)
Castrol BOT 720 SAE 75W90 GL-5 oil. This is proprietary formulation by Castrol, but there is no reason to expect that it is anything special and other synthetic 75W-90 GL-5 gear oil with limited-slip additive won't work. However, if you deviate from recommended, you have to accept dangers of something going drastically wrong. I wouldn't do it if it is still under warranty.
https://www.blauparts.com/jaguar-f-t...-rwd-0w20.html
Are you adding an OEM 3.31 LSD to a V6 Base? Or did you find something else like a Torsen?
My interest would not be in another OEM diff., but adding a Torsen. If the ratio change doesn't bollocks up the logic from 3.15 to 3.31, then I don't have to worry about finding the exact ratio (3.31 in my case).
mshedden (03-10-2018)
clubairth1
403
01-29-2021 10:22 AM
orangeblossom
02-28-2016 04:35 PM
