F-Type ZF 8HP Transmission Fluid Change DIY
Also, this is the procedure approved by the company (ZF) that manufactures these transmissions. As always, do what works for you.
DC
DJS (01-14-2024)
As Atwell suggested above...This is the approved procedure and keeps the tranny in top shape if you continue to do the maintenance. To do a "flush", you need special (expensive) equipment, and you will likely never get ALL of the fluid out, without tearing the transmission completely down.
DC
DC
I think that if I repeat the operation in 2-3 years I could avoid creating residues inside the transmission.
Carbuff2 (01-15-2024)
jahummer
03-12-2021 10:10 AM
