f-types burning
#61
#64
#65
#66
#68
As for the fires, has something like a broken/separated fuel line, or that high pressure fuel rail been excluded as a cause? Has any cause been established in Germany? I understand it would be tough given the magnitude of the destruction of those cars.
Again, have we any examples of this in the US or other countries?
#69
Received 6,307 Likes
Make what? BMWs,oil pressure gauges or pressure transducers?
#70
The recommended 0-20W oil appears far too thin for any high temperature driving. For my new Stingray, GM recommends 5-30 oils for general driving but, since the engine oil temps in the Stingray quickly rise to 300 F, GM recommends 15-50 W Mobil 1 for track driving.
Personally, I use 15-50 for everyday driving as it provides a good safety cushion of 30-35 F degrees of additional breakdown protection over the 5-30 oil and likely more over the 0-20 oils.
Not having any idea how hot the Jaguar engine oil runs under high RPM driving conditions is like playing Russian roulette with your engine. If the Jag oil temps are running similar temps as the Stingray at high RPMs (300F+) then I would say that the 0-20 oils are going to be highly suspect for providing that protective film between the moving parts.
I live in an area where the temps during the summer are almost always over 90F, every single day. You push an engine at high RPMs (4000+ sustained) under those temps and, unless proper engine oil cooling is provided, your oil temps will exceed 300F and with the 0-20 oils you would be risking engine damage.
It is simply unbelievable that Jaguar does not provide temp readouts for all parameters, engine oil, coolant and transmission oil.
#71
#72
I have to correct myself:
- it's not a specific german problem
- V8 seem also to be affected.
SAJWA6GL0EMK08004 2014 JAGUAR F-TYPE V8 Copart Cars
keep the fire burning
Stefan
Stefan
#74
#76
RE: the concern about oil temperatures
Has anyone pulled a sample and sent it off for analysis after 5K miles or so? I will be, but even though I'm down less than a week before expected delivery, it'll be a bit before I've racked up several thousand miles. However, I will be getting delivery just in time for the heat.
That'd show if the oil is breaking down.
As for gauges? Those are getting more and more rare. Agreed that the F-Type should have them though, given it's sporting inclination. I suspect that they were left off to avoid confusing what is probably the bulk of their customer base.
#77
I usually do this right after the break-in period. But it'll be several more months before I hit that at least. I am sure someone else here will have the opportunity earlier than I. I think we need to find someone with a V6S at least, as they seem to be the target demographic here.
#78
#79
DFW
10-01-2015 07:22 PM
Malihide
09-29-2015 03:21 PM
